Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother mfc-240c printer error message unit unable 43
Can you tell me what to do for:brother mfc-240c printer error message unit unable 43
  • Tina Shaw
    Tina Shaw May 11, 2010
    What happened that may have caused the error?
  • Antonio Rivera
    Antonio Rivera Nov 24, 2016
    I donde Knows, i just turn on and read the mensaje " una ble unit code 43"
    Loyalty:
    Visited the website for 30 consecutive days.
  • 121 Answers
Http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Posted on Nov 25, 2016
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
pineworks
  • 4041 Answers
SOURCE: brother mfc 240c error says print unable 51
Hi Ok try this it may work.
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: MFC-240C PRINTER DISPLAYS "INIT UNABLE 4F" WHEN TURN ON
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
SOURCE: brother MFC-240c clean unable error
To reset purge counter back to "0" then it will work again.
Posted on Jan 30, 2009
komguy
  • 2306 Answers
SOURCE: Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Posted on Jun 23, 2009
It says init unable 40 or init unable 43. it
Brother warranties for one year, you can call
1-800-276-7746 and they can give you the nearest service center.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Trouble shooting and routine maintenance
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Clean Unable 46
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
670 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
