Question about JVC Everio GZ-MG21 Camcorder
JVC Camcorder Lens stuck in fully zoomed postion
I have a JVC GZ MG - 155U Camcorder. The lens got stuck in the longest zoom. Called Costco Conceirge Services and they are directing me to JVC Customer Support since the warranty ran out.
In general, Costco would take it back. But, it's not the case now :(
I have same problem
Posted on Apr 01, 2010
JVC GZ MG 155 U camcorder no longer focuses in the auto or manual mode. When powered on, the display is fuzzy.
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Mar 06, 2011 | JVC Everio GZ-MG155 Camcorder
Zoom is stuck
Zoom assy may be defective or problem with the lens. Try moving the zoom lever back and forth a few times. Sometimes, something in the lens will get stuck and it just takes a little repetition to get it "unstuck". If this does not work, you will have to have it repaired by an experienced technician. <a href="http://www.austintelstarservices.com">www.austintelstarservices.com</a>
Aug 30, 2010 | JVC Everio Digital Camcorder
Hello, I need a manual for JVC Everio GZ MG 155U.
You can find the manual here: http://books.jvcservice.com/booklist.asp?Model=gz-mg155
Has the MG155UC and also the MG155US Manual.
I hope this helps :)
Feb 19, 2009 | JVC Everio GZ-MG130 Camcorder
JVC GZ-MC 500 NO DISPLAY
if the fault does not repair after tapping camera after switching on , its best to show to an expert repairer . This is a critical fault with the aperture of the camera getting stuck in closed position . Zoom lens has to be opened .. Maxx
Jan 03, 2009 | JVC GZ-MC500 Memory Card Camcorder
I have a JVC Everio GZ-MG155, and the zoom is stuck at 1x.
did you try holding down the record button and the picture snap shot button at the same time to reset it? It did for me.
Nov 25, 2008 | JVC Everio GZ-MG155 Camcorder
Won't zoom out
This seems to be a common issue.
Mine was stuck at what seemed like max optical zoom.
When i would look in the lens I could not see the zoom lens. If you can not see your zoom lens and the optical zoom seems stuck I bet your camera has the same STUPID issue that mine has.
It was out of warranty and I figured I had nothing to loose so I took it apart to see if I could fix it, turns out I was able to fix it just by taking it apart and putting it back together!
Taking it apart is simple enough for the average handy man, if you do not have confidence that you can take it apart then do not attempt this repair.
Take off the bottom cover.
Take off the Hard drive cover
Now remove the three screws under the hard drive that hold the drive's plastic housing in.
Remove the screw that is right under the record button, now the drive house should be loose.
Disconnect drive cable from board and remove drive and housing.
Take off the plastic piece that has the zoom button, be sure to gently disconnect the wire.
Remove rear piece.
That screw marked with an arrow on the bottom, do not remove it!
Now remove the thin metal piece to expose the flat cable.
disconnect flat cable from board
gently flex it out of the way so you can disconnect the cable behind it.
Once you have both disconnected remove the circuit board.
unplug the flat cable on the back side.
Now remove the front piece.
At this point you are nearly there!
Now remove the metal housing that holds the lens assembly.
Once removed remove the lens assembly by removing the three screws.
If you thought that was bad, this next part will scare you.
Make sure you are in a very clean room with no fans blowing.
Remove the CCD from the rear of the lens assembly by removing the two screws on the back that hold it in place.
Remove the foam and square lens piece that were behind the CCD.
On the side of the assembly is a screw that holds the top cover in, remove it and gently pry off the top cover.
looking inside you will find the following:
on the CCD side is the focus lens.
in the middle is the shutter
On the side farthest from the CCD is a zoom lens.
On mine the zoom lens was not close to the shutter
If your zoom lens is not close to the shutter then you likely have the same problem as I had and you can fix yours!
If not, you likely have some other issue :-(
To fix mine I turned it over and I loosened the screws that held the motor and shaft for the zoom lens.
Then I slid the zoom lens as far back as it would go towards the shutter.
Then tightened the zoom lens motor and shaft mount.
Put it all back together, installed battery and bingo it's working again!
Why did this fix the problem?
Well there is a little sensor that tells the camera that the zoom lens is near the shutter.
Each time you turn off the camera it always puts the lens in that "home" position.
If the camera is turned on when the zoom lens is not in this "home" position then the camera seems to assume the zoom is broken and you end up with the infamous JVC stuck zoom issue.
My guess is this problem is caused by any of the following:
1. Removing the battery while the camera is turned on
2. Dropping the camera while it is on or off
3. Battery going dead while camera is in use
Final thoughts before you get started:
1. If you are not good at working with tiny parts or electronics, I wish you luck because you will need it. Might be better off printing these instructions and taking them with you to a repair facility and paying someone more familiar with this sort of work to fix it for you.
2. The ribbon cables are removed easily. Each one has a clamp that rotates to release the ribbon. Some rotate towards the ribbon to release, others work the opposite. It is quite obvious looking at them which ones go what way.
--e100
Sep 03, 2008 | JVC Everio GZ-MG21 Camcorder
JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
Aug 04, 2008 | JVC Everio GZ-MG130 Camcorder
Everio gz-mg 155u won't focus
I called Costco, the retailer I purchased the Everio at in Dec. and they said my labor warranty has run out. They gave me instructions to send the video camera to JVC for repair. If this is a common problem with this unit, I am hoping they will not charge for labor. They should provide at least a one year parts and labor warranty!
Jul 11, 2008 | JVC Everio GZ-MG21 Camcorder
Blurred video
send ur camcorder to the nearest JVC service centre,maybe the lens need to change.They will do 'adjustment' for u..maybe..
Mar 13, 2008 | JVC Everio GZ-MG21 Camcorder
JVC Everio GZ-MG21 Camcorder Logo
460 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
