Question about RCA HD52W66 Projection Television
RCA HD52W66 convergence problem
My parents have a hd52w66 RCA TV with convergence problems. RGB is out of alignment while the screen is also concave. I have seen many solutions to this issue, but none seem completely accurate. There is no menu option to auto converge as suggested. This TV uses 4 transistors per color verses the 2 STKs on one board. The board traces seem fine. Is replacing the board going to help or is this a power issue?
  • RCA Master
  • 8,617 Answers
You will need to replace FL231, DL231 and CL230 all located on the deflection board . You can get replacements at the following link with free instructions on how to do the repair. the parts are all listed under the RCA parts category. Heres the link
Posted on Jan 16, 2009
My tv comes on but the color is distorted and not focus then after awhile it shrink out what the problem
Posted on Feb 23, 2010
Hello barrow409,
Welcome, and thank you for using FixYa!
To answer your question: Your video tuner board is going out.
This part will need to be replaced by your TV Repair shop, unless you can do it yourself. I have provided a link to the board on eBay!
Video Tuner Board
Have a great day!
Sep 12, 2011 | RCA HD52W66 Projection Television
RCA HD52W66 Television convergence is screwed up and gone from the set up menu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Jan 25, 2011 | RCA HD52W66 Projection Television
By admpeek on Jun 25, 2008 When I turn it on the picture is concaved, the color is shifted slightly to one side, and there are 3 skinny lines across the top. I went to convergence menu and clicked it...
You have a blown fuse on the Deflection board FL231 it will be on the righthand side of the flyback Transfomer there are 3 of them in a row they will look like small brown retrangler caps, it will be the one in the middle. I had this problem myself just several months ago, replacing this fuse fixed the problem. That fuse controls the convergance of the 3 CRT's, without it the tv can't converge so you don't get the option in the menu.
Sep 17, 2010 | RCA HD52W66 Projection Television
3 D picture. Double letters, etc
Tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board,must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 06, 2010 | RCA HD52W66 Projection Television
Autoconvergence will start and then stop within 3 or so seconds. This is a 52" rear projection. Colors are a little off.
Ur tv convergence are dead.The convergence board require the 2 STk convergence ICS and some or all it resistors.Must be change to solved convergence problems.U have soldering tools,solders,and know how do soldering?Tries websites like, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 18, 2010 | RCA HD52W66 Projection Television
52 in rca tv model #hd52w66
Your Convergence circuit is in need of repair. I suggest call ing a Sevice Tech.
Apr 24, 2009 | RCA Televison & Video
Ceck CP150 and CP114 to see if the tops are domd eve slightly if so they will need replacement. They are both located on the deflection board where the flyback is also located.
Jan 16, 2009 | RCA HD52W66 Projection Television
Open Fuse FL231 will cause your problem.
Aug 06, 2008 | RCA HD52W66 Projection Television
My HD52W67 has concaved picture
This is a convergence problem and can be repaired relatively easily. If you can solder, you can fix this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heat sink and should be marked STKxxx.
Keep us posted.
Jun 25, 2008 | RCA HD52W66 Projection Television
convergance ic are bad and maybe resisters.
check this site out:
Dec 11, 2007 | RCA HD52W66 Projection Television
RCA HD52W66 Projection Television Logo
497 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
