Question about ASUS A8N-VM CSM (00610839133826) Motherboard
USB PROBLEM- Hey its me Shademon
Hey its me Shademon. I had usb problems and I was wondering the same thing you told me. That i should get a pci card with usb ports on it. Do you think that would work? My usbs back and front do the same thing. How do I know the Pci card i get wont do the same thing. Aren't all usb connections connected to the same thing, the motherbaord? Just holler at me when you got a solution. Thx........
  • 42 Answers
Shademon - I'm assuming that the drive letter change didn't help? If not, here's the deal. When you installed Vista over XP you may not have had all of the correct drivers installed. There is still an option. Try going to microsoft update and running cutom updates, down the lefthand side you should see a list of "hardware" updates download and install all of those, perhaps there is a driver update for vista. If that doesn't work you probably have a few ports that are direct soldered to your mobo, but you've probably also got a few in the front that run on a 4 - 8 pin cable to your board. You can also buy a card that should go into your vacant PCI slots (make sure it's vista capable) and you should be able to install the drivers/software direct via a CD with the new hardware check out these products newegg is pretty reasonable price http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=PCI+USB hope this helps let me know if I can answer anything else.
Posted on Jan 06, 2009
Can i use a usb 2.0 or 3.0 pci card with compaq w6000
PCI is an industry standard and you should be fine using the PCI USB card but you need to make sure your operating system will be compatible with the PCI card that you purchase. It will tell you right on the package.
Aug 25, 2012 | Compaq Evo Workstation W6000 PC Desktop
How to upgrade to USB 2.0
hi this could be that the usb ports on your system are only usb v1 and not usb v2, if you require your items to run on usb v2 you will need to get a usb v2 pci card the things will work still just at a reduced rate of speed there will be no drivers for your usb ports to upgrade them as it is hardware related and not software related, usb v2 cards are generally cheep to buy and easy to install and set up....hope this helped
Feb 25, 2010 | Computers & Internet
USB problems, 2x not supported. I am told I need
its hardware does not support USB 2, you have to buy an add-on PCI card with USB 2 ports, something like this:
http://www.startech.com/category/parts/usb-firewire/io-cards/usb-cards/list.aspx
Jan 04, 2010 | EliteGroup K7S6A Motherboard
Slow Wireless
I'll assume from the wording of your question that you are using a USB wireless adapter.For the most part you get better performance out of a PCI wireless card (and better range) but you should also run a scan and clean with this program to make sure that your performance issues aren't due to spyware or malware also.
Feb 21, 2009 | Dell Dimension 3100 PC Desktop
USB not recognized and im confused!
most likely the flash drive is defective.
if it giving you the same problem on other computers, thats most likely the case
Jul 31, 2008 | Electronics - Others
Adding a second graphics card?
Hey there sven155, If i were you , I would get get the video card for the AGP slot. The main reason is the interface is much more efficient, and as a result the dual monitor output would be better in quality than you can get out of a PCI card or any USB connection. Another option is to have your TV Wonder plugged into the computer via AGP only when you need it, therefore you would be switching one for the other (Inconvenient). Ideally video card on AGP, TV card on the PCI.
Alternately you can make the two work, just not simultaneously, and you would have to change settings in the bios to set one or the other as your primary video output.
Feb 12, 2008 | ASUS P4S800D-X Motherboard
How can i get my wireless rooter to work
Wireless cards come in many different forms: external USB devices, internal PCI Cards desktops, external PC (PCMCIA) Cards for laptops, and internal mini PCI cards for laptops.
What type of computer are wanting to make work with your wireless router? Laptop or PC?
Feb 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
USB 2.0 PCI Host Card CPQ5PHC
Let me know if your pc is running with winxp if winxp there will such problem doesnot exist. but in case of win98 you have to test drivers which is available in win98 and match to usb pci
follow this procedure
go to mycomputer
right click
select device manager
right click
click on scan for device
new hardware instalation wizard
search for new hardware
automaticaly update drivers
check one or more driver
try
and save which is compitable to your pci usb
Oct 16, 2007 | Micro Innovations MCNCPQ5PHC USB PCI Card...
Video export problem
what are you using the transfer the video USB or Firewire
Aug 30, 2007 | ATI All-in-Wonder 2006 PCI Express ,...
ASUS A8N-VM CSM (00610839133826) Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
