Question about Gateway MX6447 Notebook
Gateway 8715 masss storage controller
Hi i have uninstalled and reinstalled this driver even in safe mode. I still have a yellow question mark.
I talked to the gateway techs and gave me the same driver as on there support site.
It does not work and what makes it worse windows keeps asking to install the driver.
Help please
    Scholar:
  • 35 Answers
Keyboard inoperative on HP notebook
Do they work in safe mode ?
Restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click you will need to update the driver Click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 arrows >> then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
http://www.microsoft.com/hardware/download/download.aspx?category=MK complete range of drivers
Feb 06, 2013 | Computers & Internet
When booting the cp is going to power saving mode
Unplug power sources for the monitor and computer.
Hold down the power button of the computer tower for 10 seconds, this will drain remaining from the motherboard.
Plug back in the power sources for the monitor and computer tower.
Power on the monitor first, make sure the monitor power button will turn green then amber.
Power on the computer tower.
Try to check if you were able to see the Dell blue logo just right after you power on the computer.
If you were able to see the Dell blue logo then do these steps:
1. Turn off computer then turn it back on then immediately keep tapping on the F8 key. If options will appear please select safe mode.
2. If you were able to access in safe mode the problem we have is the video card driver needs to be uninstall then reinstall. To uninstall/reinstall the video card driver. Once you access the safe mode go to device manager then uninstall the display driver. Reinstall the display driver using the CD drivers came with the computer.
3. If you were not able to access safe mode then try again step 1, when you reach the option screen then select "last known good configuration".
If all fails from these steps, back up your HD files by asking a local tech to use an enclosure to copy all your data from your HDD to a different storage cause this will end up reinstalling the windows operating system.
Just in case just right after you power on the computer and it immediately gave you the message entering powe safe mode then you need to re-seat the video card which needs to open the side cover of your computer.
Re-seating the video card ut's just like taking it out from the slot then put it back again, make sure it's properly seated.
Jun 30, 2011 | Dell Dimension 2400 PC Desktop
Hi. I am running Windows XP on a Gateway 450ROG and I have no audio, mixers or otherwise. I have installed/updated drivers, uninstalled and reinstalled, etc. I also have no audio listed in BIOS. Is that...
the yellow exclamation mark your driver needs updating
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Computers & Internet
I attached the G-Max 2000 speakers that were on my XP Gateway to my Windows 7 Gateway. Though the device manager says they're working properly, no sound is coming out.
hope this helps
Jan 23, 2011 | Gateway GMAX 2100 Computer Speakers
Earlier it works good, but now the sound is gone.p4m800p-m7 biostar motherboard..all drivers are installed....
Boot the OS in safe mode and uninstall the sound driver from machine. Then boot in normal and reinstall the sound drivers from the driver recovery disc given by the manufacture while buying the machine.
TO go into safe mode:
Press F8 while you turn on your system(before windows logo comes) and Choose safe mode from the options on the screen.
Aug 02, 2009 | Gateway Computers & Internet
Mass storage controller driver
Greetings,
IDE controller starts to install the driver automatically as soon as you restart. The best way to get it completely removed from your comp is that in case you are using Windows XP or higher version goto Safe mode by tapping the F8 key on the keyboard on restart. goto control panel to Add/ remove programmes and uninstall the software completely. I hope I helped you out.
Regards,
TechSup1
May 01, 2009 | Computers & Internet
Facing problem with my acer notebook
I assume you have been to your control panel and chose network and Internet connection. under pick a control panel icon you will see wireless network setup wizard. walk through that.
You may have to set it up again.
Maybe this will help
Jun 05, 2008 | Computers & Internet
Installed the drivers from the Gateway Web
i have a suggestion:
right click on the yellow exclamation mark then update driver then search for driver automatically if nothing happens go to manufacturers site and try downloading the driver to them directly.
May 29, 2008 | Gateway MX3560 Notebook
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
Gateway MX6447 Notebook Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
