Question about RCA F36650 36" TV
Need diagram of how to hook up reciever dvd vcr
Where to buy a manual
  • 716 Answers
You Can Print One If You Want Off The Rca Website
http://tv.rca.com/RCATV/NewTV/Templates/SupportDownloads.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2fproductdownloads%2ehtml&NRNODEGUID=%7b35D79B02-4AAE-4834-BFD0-1124EA501FA2%7d&NRCACHEHINT=NoModifyGuest
But For Some Reason It Doesn't Have The 50 Only The 49.
Hope This Helps If Not Try Calling Rca And They Will Probably Send You One For Free.
Posted on Jan 06, 2009
    Genius:
  • 2,035 Answers
Please click here
Good luck...
Lost my manual I need to hook up to my cabel box. plus what cabels i need for my dvw5000
here is a basic diagram of cable connection from a cable box to a vcr and to the tv.diagrams_hookup_tv_dvd_cabl.jpg diagrams_hookup_tv_dvd_cabl.jpg
Feb 06, 2011 | Sanyo DVW-5000 DVD Player/VCR
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
I need a copy of the owners manual.
are you using rca for dvd?? or digital cables? if you are using digital cables make sure your reciever is set to digital not analog
why would you want them both working the same time ?
if you are recording, then make sure vcr is plugged "out" not "in" connections
May 05, 2009 | Audio Players & Recorders
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot hook up DVD and VCR to Vizio 37 inch flat panel 2003 model
try connecting the output from the sat reciever into the in ant incoming signal of the vcr use the dvd as one of the inputs to the vcr use remote from vcr to switch from vcr to dvd.
hope this helps
Dec 28, 2008 | Vizio L37 Television
Very low sound on TV and DVD no tuner
audio out from your tv to your reciever gives low output? how do you have everything hooked up i have vcr to tv dvd to vcr audio to my reciever and vcr tv thru piggy back plugs therefore i can only have tv audio or reciever or both
Dec 03, 2008 | Denon AVR-2800 Receiver
Hook up,s
Hi-I used to be a DirecTV installer. Depending on the type of reciever you have, there are yellow/red/white or red/green/blue outputs on the back. You will need to run the dvd/vcr through these and then change the tv to video 1/ video2, or AVI, CV1, CV2, Front (or whatever acronymn your tv has) when you want to switch between the componet and the reciever.... you should only need to change the tv channel to be able to use the dvd player. I've found that vcr's usually need to be on channel 3 and if DirecTV is using ch 3, you may have to slide the button on the back of the reciever to ch 4 instead.
Jul 24, 2008 | Televison & Video
RCA F36650 36" TV Logo
216 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
