Question about Philips DVP642 DVD Player
Disc error philips dvd 616 k.the machine will play discs bought from the store but when I try a disc that I have recorded myself on my Panasonic dvd recorder,It comes up with "disc error" the disc in question was a recordable disc DVD - RW.
  • 1 more comment
  • Victor Bennett May 26, 2007
    Thank you 24 seven..I did not finalise the disc originally but have since done so and now everything is operating as it should.Much appreciation for your help
    veebee
  • Victor Bennett Aug 23, 2007
    what is divx format and how do I use it.?The dvd is of a movie that I copied from the T,V.thanks for taking the time to help me with my problem.
  • Anonymous Mar 27, 2014
    program is not recordable
Make sure that the file you recorded is in divx format before you burn it onto a disc.
Posted on Aug 22, 2007
    Scholar:
  • 125 Answers
Your not alone some people have probles with this player too, here is what other owners say: http://www.videohelp.com/dvdplayers/philips-dvp-642/4117
Posted on May 25, 2007
  • 883 Answers
After recording, did you ensure the "finalize" or "lead-out" process completed?
I have recorded on a Verbatim DVD+RW disc on my Philips 3305 DVDR but it will not play back on my friend's Panasonic DMR-EX98VEB. My recorder will not finalise/make compatible the disc. Why?
Could be that the disk itself is incompatible with your friend's machine. Or your buddies machine may be starting to exhibit playback issues. Try another disk and see what happens.
Feb 07, 2016 | Panasonic Televison & Video
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
My Philips DVD Recorder does not accept a DVD disc shows no disk. The DVD disc does not revolve. A CD disc revolves but shows junknown
Could be that you are using the wrong type of DVD ? There are two formats DVD+R, DVD+RW etc and DVD-R, DVD-RW etc. Some machines are capable of using either, others can use one of the two formats.
My other suggestion is that some machines are picky about which manufacturer's DVDs they will use.
6.November.2015
https://en.wikipedia.org/wiki/DVD_formats
if you have an error code this might be useful
Dvd recorder won record on DVD RW disc
Some possibly relevant answers here which suggest my answers above
http://www.digitaltvbanter.co.uk/uk-tech-digital-tv-digital/25025-brand-new-panasonic-dvd-recorder.html
Nov 06, 2015 | Philips Televison & Video
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Mar 30, 2008 | Panasonic Diga DMR-EH75V DVD...
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD+R will not play
2 Things 1 You need to Finalize the disc to play of a DVD player check that out with your DVD burn program. 2 Check the DVD players capability with certain discs, not all payers will run 'burned disks' sometimes even the brand of disk matters or whether it is + or- type There are may variables with the DVD firmware. Finalize first the the first step.
Jul 31, 2007 | Emerson EWD7004 DVD Player
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Philips DVP642 DVD Player Logo
207 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
