Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite flashing codes.
Ok here it is…I have a Kenmore Elite110.2206, purchased in 2002 ish. Two years ago I replaced the pump. (under-wire problem) It has worked fine to this point. It has started flashing ob and ld. We took it apart and found a penny and a dime in the hose and took apart the pump cover and removed some debris. Put it all back together and now it is flashing again and it is now leaking out the bottom. It is also not draining the water out all the way from the rinse cycle. Was I suppose to “reset it” or something? I really do not have the money to call the repairman out, nor do I want to have to buy a new machine.
  • H. Hood Jan 06, 2009
    I should have said I took all the clothes out and it wont drain at all. I have tried to run a short cycle, express wash, custom program none will drain the washer.
  • H. Hood Jan 08, 2009
    Day three of the saga. We have taken the machine apart again. Manually drained the tub-again. There was stuff around the black pump impeller cleaned it off-again. Double checked all the hoses reattached, again-hopefully they will not leak....Also cleaned the area around the lid just in case that was giving the lid open signal. One big question remaining, what do you mean in the above comment by "both pumps". I see the pump with the two hoses, one in and one out, black and yellow. I see the motor for the tub but alas no other items resembling a second pump...Humm?
    PS. First very small, trial load completed washing fine, our fingers are crossed.
  • 318 Answers
Ob means out of balance and ld means lid not closed. so i would guess that you have a washer that is not draining or just needs the clothes moved around.
if you have a plugged pump it will do the same thing. make sure the pump will drain properly and then try it again. if it still goes out then try it with no clothes. that way you know its not hte clothes causing the problem.
recheck the pump and hoses. be sure it will drain the full tub or it wont work right.
Posted on Jan 06, 2009
  • Tom Zwiebel
    Tom Zwiebel Jan 07, 2009
    ok since now we know the unit wont drain, then there are 2 things to check next. make sure the lid does close and lock so the machine can run, and if it does try to run, but wont drain, then you need to check the drain pump to see if it is blocked with something like a quarter or a sock.
    you can get to the pump from the rear panel and then be ready to catch the water so you can remove the hose going into the pump. do check both pumps, 1 is for recirculation and the other is for draining.
  • Tom Zwiebel
    Tom Zwiebel Jan 08, 2009
    your unit probably doesnt not have the second pump. it is used for recirculation on some models, but you didnt have a complete model number so i had to guess which one you had.
    i would guess that by cleaning out the pump, you took care of the problem with it not draining and now it should be fine. that is until you get a plugged pump again. sorry about the confusion. good luck in the future and now you know how to check that pump and hose if it happens again.
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Kenmore elite he 5t the code f21 comes on, the hose is ok.
This is a Long Drain Issue. Likely that something is stuck in the pump trap. Take off the mottom tree screws under the drum panel. This will remove the drum panel on the front. From under neither you can see the drain pipe trap. Unscrew the trap cap in the from. Clean out all debris and re-install. this should do it.
Feb 15, 2010 | Kenmore Elite HE5t Washer
I have an F 02 error on my Kenmore elite. The
Accessing the Drain Pump on Kenmore Elite and Whirlpool Duet Front Load Washers
  1. Safety first. Unplug the machine.
  2. Put a blanket over the top rear edge of the machine to cushion it and lean it against the wall.
  3. There are three screws located right at the bottom front edge of the machine securing the toe panel. Remove the screws and the toe panel will fall off.
  4. Open the door covering the wiring harness connector and disconnect the wiring harness from the terminals of the pump motor.
  5. Remove the screw securing the pump assembly to the frame of the machine.
  6. Remove the drain hose and tub outlet hose from the drain pump assembly.
  7. Put a small pan or bucket under the pump and turn the large knob counterclockwise to remove and clean the large item filter.
  8. Unscrew the drain pump from the pump housing and check the impeller for any obstruction or damage.
  9. Replace the drain pump if the impeller is damaged or if no obstruction is found in the drain hose, tub outlet hose, and the large item filter.
  10. Install the new drain pump in reverse of the removal steps above.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Kenmore elite he3t model 4596640 year 2005 f33 code
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Clicking in the water pump for the Kenmore Elite H3 Washer
F2 if nothing in pump replace pump, propeller inside is bad. "less soap plz "
Nov 15, 2008 | Kenmore Elite 45986 Front Load Washer
Flashing F6 Error Code
motor controller board in bottom
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore HE3t DL code
My husband and I had this same problem, but after visiting this website and reading through some of th posted solutions, we were able to fix our problem. Our 3-year-old Kenmore Elite H3 would not start on any cycle. It kept flashing the error code "dL/F", which we found out means "door lock failure." Taking advice, we unplugged our machine, removed the top panel, and rechecked the wiring. It worked! We think the wiring may have become loosened over time due to the jiggling vibration of our machine. Hope this helps you!
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
218 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
