Question about Clarion DB-225 CD Player
Can't Reset clock on deck
I would like to know how to set the clock on my db225 clarion, and why when I put a cd in it shows er 3 and er 6 if anyone know the answer to these it would be extremly helpful. Thanks
  • 196 Answers
The manual has your solutions, and is available here: http://www.clarion.com/us/en/MungoBlobs/662/481/DB225(Manual).pdf You may have to go in from the main site (www.clarion.com) to reach this pdf file.
Posted on May 25, 2007
Clarion vx400 clock wont maintain time
There are three main wires that control the power of any deck. They are as follows:
  • Bat+(12v) -RED- This is the main power wire. There is no mistaking this wire
  • Ground -Black- ground wire that is usually connected to the frame.
  • Constant -Yellow - This is the wire that provides a constant low voltage to the deck when the ignition is turned off. This is the wire that maintains certain functions such as last position on CD and also for the clock to maintain the correct time.
The constant wire is the one you are looking for. The best way to find the constant wire is to take a test light and probe till you find it, when you are doing this make sure that the ignition is off. In this state only the constant wire will set off the test light. Good Luck and let me know if you need any more help
Jan 28, 2012 | Clarion Car Audio & Video
The used car i bought has a clarion bd216 in it, and i burned some CD's and put them in and they play when they want to, but most of the time when i try to skip to the next song it says er- 3. any idea...
That unit doesn't really do burnt discs too well. I would advise replacing that radio with a new one that has MP3 support etc. You can get a good Clarion, Kenwood or JVC for around $100.
Oct 26, 2010 | Clarion BD-216 CD Player
Set clock on m2455 radio/cd
since i don;t know which version you have of that unit here is a link with manuals just pick the version and it will tlel you how to set your clock.
Clarion
Mar 26, 2010 | Clarion M255 AM/FM Marine CD Player
What format and speed do I record an audio cd for a Clarion DB225. and does it have to be finalized? anything else I should know?? thank you. brb366@Gmail.com
Cd's are done with the .cda format.
128kbs seems to be a good speed.
I dont like cd's my self. I use Ipod. It holds all of my songs, and cant be scratched.
Mar 16, 2010 | Clarion DB-225 CD Player
I need the wire color code for the clarion db225 ,so i can install it .
Red = switched 12V
Yellow = constant 12V
Black = ground
Blue/White = power antenna
Speakers are a color set, one with a black stripe
White set = left front
Gray set = right front
Green set = left rear
Purple set = right rear
The RCA plugs are pre-amp out.
Dec 27, 2009 | Clarion DB-225 CD Player
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
Set Clock for a Clarion DB336MP
You can find the instructions at: http://akamaipix.crutchfield.com/Manuals/020/020DB336MP.PDF
Page 11 give you info on clock setting.
Or try this:
1) Press and hold the [BND] button, and then
press the [DISP] button to display the clock
display.
2) Press and hold the [BND] button, and then
press the [DISP] button for 2 seconds or
longer.
3) Press the [d] button, then set the current
minute.
4) Press the [a] button, then set the current
hour.
5) Press the [BND] button, then the clock is set.
Nov 25, 2008 | Clarion DRB2475
Clock setting for Clarion DXZ555MP Radio / CD Player.
Just go to the website and click on the 'download manual' link on the right side. Here is the page on Clarion USA, for your cd player.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
There you can download your owners or installation manual in PDF for free. Nice to deal with a company like them isn't it?
Sep 29, 2008 | Clarion DXZ555MP CD Player
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Aug 05, 2008 | Clarion DXZ665MP CD Player
Clarion DB-225 CD Player Logo
209 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
