Question about HP Photosmart C5280 InkJet Printer
I have a Photosmart C5280 Have changed colour cartridge for the first time Alignment has failed twice Book tells me to contact you Print cartridge alignment failed.
  • Anonymous Feb 04, 2009
    wont align cartiage staal
    Genius:
  • 2,035 Answers
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
then try to print if the alignment fails then you need to change the cart in the
printer if its original hp new cart then get replaced .....
Good luck..
Posted on Jan 06, 2009
My Hp C5280 photosmart printer keeps failing to properly print the alignment page, I just now change the black, is it possible that since my color is out that it will not print properly?
Yes this can happen.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 20, 2011 | HP Photosmart C5280 InkJet Printer
Hp photosmart c5280 Cartridge Alignment problem. everytime I try to print it tells me to run alignment test, and then when the alignment is off, it won't let me print...HELP!
Please follow the below steps. After evry step, if the cartridges are not allign automatically, allign it manually by the below steps.
To align the cartridges from the All-in-One
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Then scroll using the down arrow key and select Tools then select Align print cartridge or Align printer.
STEP 1.
Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Apr 28, 2010 | HP Photosmart C5280 Printer
Hp photosmart c5280 all-in-one printer........the color ink cartridge will not allign
I had a similar issue, I called HP Support and they had me change out the ink, re-run the alignment, restart, change out the paper, run the alignment again. They had me try everything you could imagine. But, in the end; there was absolutely nothing that would fix it. They said that pulling paper jams from the printer among other things (if not done properly) can permanently damage the print head to where the alignment can no longer correct it. Luckily, while it took forever, the printer was under warranty...I had to do a warranty repair, but the new printer had no issues.
Mar 08, 2010 | HP Photosmart C5280 InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Jan 18, 2009 | HP Photosmart C5280 Printer
Hp c5280 printer
Its the cartridges...... you will have to get more or new ones. I changed mine after a week of fiddling around - and printer worked perfectly. Wish the error message had been specific, then I would not have wasted all my time. The cartridges that didnt work were brand new HP 350 and 351 cartridges - straight from the packets, but the printer "didnt like them"..... A waste of money but Im going to try and put them back into machine tomrrow and see if I can fool it!!!
Jun 08, 2008 | HP Photosmart C5280 Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart C5280 InkJet Printer Logo
524 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
