Question about Jandy AQUALINK RS TELELINK KIT
System when dead
My control panel was open and got wet. One program started the lights then the total system went dead in a frac of second.. I Checked the breakers to the unint and they did not trip,, Is there a breaker in the control box also /
  • 2 more comments
  • neal_cornwel Jan 06, 2009
    The control panel is an aqualink rs. ... My indoor control panel  lights up completely when I turn on the breaker,, The power plug box on the side of the control box is getting power.. but thats it.. everything else is not working,,, : )...
    I put the power back on and everything is working,,, I guess it dried out... dodged that bullet... wow.. Thanks for the luck :)
  • khadiyev May 11, 2010
    all the lights in the inhouse panel are lit up the red light?
    do you have a spa side remote? a four or eight button?
    there is a transformer in ther make sure it's putting out voltage, what system? name brand model? you equipment?
  • 125 Answers
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Battery's are draining on a 2008 gmc duramax
Check all the interior lights in the truck, look at the visors which are the single biggest cayuse of the battery drain, look at night. Also Have the batteries tested, a shorted cell will draw them down as well. Never overlook the obvious.
Oct 18, 2012 | Cars & Trucks
Trying out program library. Cannot find "FRAC" command within the menu system or owners manual... can you help?
First of all you have a key marked [a b/c]. It is in the first column of keys, below the [X,theta, T] key and above the 7 digit key. Its second (shifted) function is [d/c] These two keys are used to enter mixed numbers and improper fractions.
The command is also accessed from the menus.
  1. In Run screen press [OPTN]
  2. Press [F6] to move to next page of menus.
  3. Press [F4:NUM]
  4. Among the menu Tabs at the bottom of screen there is the Frac Menu.
  5. Press [F3:Frac] to access it.
Sep 23, 2010 | Casio CFX-9850G Plus Calculator
I can't find the System Recovery option in the Control Panel after I went from Windows 7 back to Windows Vista due to some problems.
you will not find system recovery options in control pannel, as it is either in the systm tools or you can get it from advance boot menu options by pressing F8 key on start up of computer ,
second way to get system restore is type system restore in start search box and it will show it , third way click on start then all programs , then accessories then system tools , you will find option of system restore.
Sep 04, 2010 | Computers & Internet
Programing a new remote
Use these instuctions if your Deville has an Analog Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Panel (CCP) simultaneously.
(Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode.
Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP.
If “RFA DATA” is displayed, press FAN DOWN.
If “RFA OVERRIDE” is displayed, press FAN UP.
2. If “RFA 500 NO OVERRIDE” is displayed, press FAN DOWN.
If “RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP.
3. IPC will show “0” on right side of Driver Information Center (DIC) display.
Press warmer button on climate control unit until “99” is displayed.
4. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not
programmed within 30 seconds after entering “99” override display, system will default and you must begin again at
step 2.
5. To program a second remote, press FAN DOWN button until “RFA 502 PROGRAM FOB #2” is displayed, then press
FAN UP. Repeat step 4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1. Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will
light all telltales, go blank then enter DIAGNOSTIC
MODE. Press FAN DOW button to scroll through system until
“RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then
press FAN UP button. When “NO OVRD RF 500” is displayed, then press FAN UP button.
2. When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just
below odometer. System is now ready to program remote.
3. Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one
step 2.)
4. To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to
program second remote.
To exit system, press RECIRC or RESET buttons.
Disclaimer
Apr 25, 2009 | 1998 Cadillac DeVille
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Car won't start says check traction control
the car should still start even with somthing wrong with the traction control. sounds like you have a dead battery. i would check it first. and if battery is dead charge it and start the car then take it to your local advance auto and have the altinator checked thay do it for free. if a charged battery dont start the car then you may have a bad starter. again the traction control light will not keep the car fromk starting
Oct 24, 2008 | 1998 Lincoln Mark VIII
Panasonic microwave s254bf stopped working
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to
open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Oct 21, 2007 | Panasonic NN-S254BF Microwave Oven
Jandy AQUALINK RS TELELINK KIT  Logo
279 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
