This phone has a problem with a loose charging socket. With mine, if I hold the plug tightly into the socket it will charge. When I let go it stops charging. The inexpensive solution is to tie a 3 inch rubber band to the charging wire at the plug. When you need to charge, put the plug in the socket and stretch the rubber ban up around the top of the phone. This will keep the plug securely into the socket and it will charge.
SOURCE: doesn't charge
you might have blown somthing oops and probs your phone might need replacing but you might have to pay for it
SOURCE: HOW DO I KNOW THAT MY NOKIA E71 UNIT THE BATTERY
I think the battery indicator is on right hand top corner. Please note the changes there while recharging.
SOURCE: my nokia e71 smartphone says
1st check it out the SIm card weather its working or not .........
it its not working take other number
if your sim card is working ...... i think some problem with your E71 software ....... upgrade your software
i got it looked at by the expert and he suggested that the software may be faulty once that is fixed the phone should be working perfectly again. but somehow i noticed using the wall charger works well and last up to a day where as car charger is totally hopeless >
