Question about Nordic Track NordicTrack Treadmill, A2550
Title: Treadmill Belt Problem
My belt is offcentered and threads are raveling on side.
  • connpress Jan 25, 2009
    My belt slides to the right. After I center it, it slides back again.
  • Anonymous Mar 21, 2009
    after three turns the belt on my treadmill comes off. What do I do?
    Novelist:
  • 148 Answers
Determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Posted on Jan 06, 2009
How to adjust treadmill belt
Whet taking off the rear cover on a Trojan treadmill. there is 2 threaded bars with nuts on them. you can adjust there. be sure to adjust them same turns per side or you may have problems with imbalanced belt
Feb 26, 2015 | Exercise & Fitness
How to replace a Treadmill Precor 9.31 belt
Replacing a Treadmill Running Belt and Deck Following is a basic guideline of removing and replacing the running belt and deck on a treadmill. Due to different brands and designs of treadmills, the following should only be used as a guideline. If any of the information is not exact to the treadmill being serviced, refer to the service manual or call Sportsmith for further help. Tools Needed: Phillips Screwdriver, Set of Allen Wrenches, Set of Box End or Open Face Wrenches (Tools needed may vary depending on treadmill. )
  1. Switch the Power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Remove the finger guard retaining screws and carefully remove the finger guards from the deck at each end of the rear roller.
  4. Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
  5. Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
  6. Raise the shroud and secure it with a bungee cord.
  7. Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
  8. Now remove the front roller retaining bolts.
  9. Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
  10. Loosen and remove the deck mounting hardware.
  11. Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
  12. Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
  13. When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the newly installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit.
  14. Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
  15. Be sure the deck is lined up with the frame and push the deck to the left side.
  16. Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
  17. Re-install deck mounting hardware. (Check with mfr. for proper torque during install process.)
  18. Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
  19. Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
  20. Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
  21. Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
  22. Tighten each rear roller bolt the number of turns you kept earlier for reference.
  23. Now, Plug in and power on the unit.
  24. Carefully remove the bungee cord from the shroud and lower it back into place.
  25. Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
  26. If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
  27. Caution: make very small adjustments such as 1/4 turns and then watch the belt for several moments before making another adjustment.
  28. Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
  29. Now use the unit at a jogging speed to check for belt travel or slippage.
  30. If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
  31. Install the finger guards once you have enough clearance from the rear roller.
  32. Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
  33. This concludes our instructions of how to install a replacement treadmill belt and deck.
How to Replace Treadmill Running Belt and Deck
Oct 16, 2013 | Precor 9.31 Treadmill
The belt is loose on treadmill how do I tighten it
Is the belt drifting side to side? If so, adjust it with the Allen bolts on both sides of the base. If the belt is just slipping, has your treadmill had a lot of use? If so, you may need a new belt. You can order one at Treadmill Parts
Nov 08, 2010 | Proform XP XP 690T Treadmill
My walking belt is off cener
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
May 07, 2010 | Proform 530 Treadmill Walking Belt
The belt on my treadmill is off to one side. how
Apr 27, 2010 | Exercise & Fitness
Treadmill belt keeps slidding to the side
Apr 08, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt went all the way to the right side and it sticks when walking
Mar 10, 2010 | Proform 650 Crosstrainer Treadmill
Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Jan 03, 2010 | Nautilus Exercise & Fitness
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Adjusting the walking belt
Jan 13, 2009 | Exercise & Fitness
Nordic Track NordicTrack Treadmill, A2550 Logo
837 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
