Top of screen is showing horizontal, pixelated lines running across entire top, for about 10 lines down Pressing certain letters on keypad, results in errors in print screen At some stages, the return arrow key does not respond When selecting a certain shopping category, business already past show, but none of the upcoming ones show
SOURCE: screen goes blank except for a thin line from top to bottom
Give a good healthy "tap" to the Garmin Logo on the front of the case. Garmin battery connections are renowned for their crappiness!
SOURCE: white lines across screen
normally RCA"S are common with this problem. Some of them have a knob in the back the adjust the brightness. This will sometime get rid of the lines. I did it to my RCA and it worked like a charm.
SOURCE: Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site:
Question: The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer:
To recalibrate the touch screen:
SOURCE: Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
SOURCE: Garmin Nuvi 660 frozen screen
Don't know why it happens, but mine did the same thing. There's a reset button on the back, underneath where you lift up the antenna. Unplug the unit from the power source, push the reset button, reconnect to a power source and it should work fine; mine did. Good luck. Got this info from my Garmin owner's manual.
