Question about Whirlpool GEW9250 Electric Dryer
My whirlpool duet does not heat up
My electric whirpool duet dryer does not heat up. It does everything it is supposed too, but when it goes off they are still wet. I have cleaned out the lint trap and the hose from the machine to the wall. Still wont work. Any advice please? I am desperate. Thank you
  • faseb Jan 07, 2009
    I have the same problem. Its only 3 years old
  • 5,911 Answers
You may have a component failure with your dryer. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
You will also need to check the voltage at the wall receptacle to ensure it is reading 220-240VAC. Improper voltage can also cause these symptoms. The last paragraph in the link explains this.
Have you checked the dryer ventilation from the wall to where it exits your home? Do you have a lengthy dryer vent run? Simply cleaning the lint trap and the dryer hose may not be enough if you have a lengthy ventilation system. You may have to have your ventilation inspected or cleaned. A simple test to determine the cause is to remove the dryer vent hose from the back of the dryer and attempt to dry a load. The air leaving the back of the dryer should be forceful and warm (about 140 degrees F). If the air is weak, you may have a clog INTERNAL to the dryer. If the air remains cold, you may have a component failure INTERNAL to the dryer. If the the dryer functions normally with no problem drying, you have a clog somewhere in your ventilation EXTERNAL to the dryer. Try these tips and let me know. I hope this helps you.
Posted on Jan 06, 2009
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
I have a whirpool duet dryer the clothes are not getting dried
heatman101
Jun 25, 2011 | Whirlpool Dryers
Lost heat for my Dryer Whirpool LER3624JQO. Discovered heating element had a break in the coil. Bought new element at local appliance store, while I was there I had all 3 T-stats tested, everything tested...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 04, 2011 | Whirlpool LER3624JQ Electric Dryer
No heat, everything else is fine whirpool module R6X3519PQ0 Type: D433 Thank you Bert
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 11, 2010 | Whirlpool Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirpool duet dryer
Press/hold start for 5-10 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
229 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
