Question about Apple iPod classic MP3 Player
Husband got Christmas ipod Classic wet
Just a couple seconds in soda, and the ipod won't turn on!!!!! Is 275 down the drain. It is not even 2 weeks old. The apple support guy says to leave it charging for 24 hrs. Best Buy says "accident." Is it worth taking to the Apple Store or???
Screen is black
  • ripptamale Jan 06, 2009
    I called and they seemed to think it was an accident and not covered by the warrenty. What should I tell them?
  • 43 Answers
Hi what seemed to happen here is your HDD drive got wet and crashed. Yes take it back. Next time this happens the second it gets wet put it in a bowl of white rice. The rice absorbs the liquid and all better. But this time you can't do it. But yes take it back.
Posted on Jan 06, 2009
  • Matthew Borquez Jan 06, 2009
    Tell them that it was an accident
First My Ipod Was Dead For A Couple Days Than My Dad Went To Buy Me A Charger & I Put It On There & Its Didnt Work So I Keep It On The Charger For Three Days & Than It Still Didnt Come On So For Like A...
What type of ipod and how old is the battery ?
iPods have revolutionized the way we think about portable music and video players. Occasionally, however, your iPod may freeze and no longer turn on or off.
Luckily, there is a simple fix for this predicament.
Toggle the lock switch on and off several times, leaving it on the off position.
Hold the "Menu" and "Select" buttons at the same time until the Apple logo appears on your iPod's screen.
Repeat steps 1 and 2 if necessary, until the problem is corrected.
iPod Touch
Ensure the iPod will not turn on or off by holding the power switch down for at least 10 seconds.
5
Hold the "Power" button and the "Menu" button simultaneously until the iPod powers off.
6
Hold the "Power" button until the Apple logo appears on your iPod.
Aug 16, 2013 | Video Game Consoles & Games
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
My ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
Blocked kitchen drain
If you have a wet dry vac, remove all the water in the sink. Then take 1 full cup of baking soda and 2 cups of white vinegar. Pour the baking soda into the drain, then pour the vinegar on top. Let it sit for about 20 minutes, then flush with scolding hot water. If that doesnt work then do it again and let it sit for longer. Baking soda and vinegar make a acid that will eat through most anything that goes down drains.
May 31, 2010 | Plumbing
My 160g classic iPod was in my computer bag and got wet
open it up it might have a sticker that you can reset on
Sep 27, 2009 | Apple 160 GB iPod Classic (Silver) +...
Wet line on the ceiling between 2 vents
You have a clogged condensate drain line and the condensate is now being syphoned up by the blower and coming out the duct work.
Find where the condensate drain exits the house and you can back flush it gently with a garden hose. Then clean out the condensate pan and pour a mixture of warm water and baking soda into the pan down the drain.
May 17, 2009 | Heating & Cooling
Ipod Nano doesnt turn on AT ALL
turn hold on then off, then hold down menu and select untill screen shows apple symbol.
Jan 15, 2009 | Apple iPod nano
plug it to your computer, load up itunes, if your ipod owners link comes up, find your factory reset button, you won't lose any music or info, it will just reset itself to the settings when you first bought, i had the same problem.
Jan 13, 2009 | Apple iPod nano
IPod Classic won't recharge
This will reset your ipod hopefully it helps
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step
  • Aug 12, 2008 | Apple iPod classic MP3 Player
    I POD NANO 2GB
    Let it dry for at least a week. Do not touch any buttons. If it is at all sticky (say you spilled soda or something on it) submerge it first in rubbing alcohol. Set it plug end down and just pretend it doesn't exist. Don't try anything with it. It MAY work a week from now if nothing was damaged. Playing with it now, while there's still water, may cause it to short out though.
    Apr 18, 2008 | Apple iPod nano
    Apple iPod classic MP3 Player Logo
    121 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
