Question about Kenmore 73952 Gas Dryer
My dryer starts runs for a few minutes then stops with an E1 on
Gas Elite. My dryer will start run for a couple of minutes then give an E1 on the display. This usually happens when the load didn't dry all the way and I am restarting it to finish drying.
  • 686 Answers
Clear the exhaust tube of lint and make sure you have good air flow out of house and also if you happen to keep anything on top of your dryer please i say this to all NEVER keep anything on top ot it. Clothes or stacked items on top insulates your cabinet and makes dryer run improperly. Nowadays with sensors and all, it fools your machine when you have stuff on top of it. Good Luck
Posted on Mar 01, 2009
I have a Kenmore Elite HE3 gas dryer that is not heating. When starting a cycle, it will run for a couple of minutes, then stop with "E2" on the display. Lint has been cleaned out from entire...
Ok
E2 means the control board has sensed problem or shorted thermister. Located on blower housing.
Replacing thermister should solve the problem. This picture should help.DISCONNECT POWER BEFORE ATTEMPTING
Elite Dryer schematic
Was thi helpful?
Aug 22, 2011 | Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
I have a Kenmore Elite dryer that sometimes the drum will not turn as i press the start button and when it does start after a few minutes running it stops turning?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 30, 2011 | Kenmore Dryers
Kenmore Elite HE3 gas dryer, runs ok for 5 minutes, then keeps shutting off with an E1 message. Thanks for helping. I read it might be time for a new thermistor. Where can I buy that part? Is it easy to...
First you'll want to pull off the top and try and wiggle every connection you see to the board located in back right. An E1 is a "faulty control" message a few hundred bucks for the part I recommend you use a service company they may charge 200.00 in service and labor, but you'll get at least a ninty day warrenty. And only they can switch out electrical parts ... You'll find it much less headache in the long run.
Aug 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73952 Gas Dryer Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
