Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Can not get into setup; shuts down when trying...
Well, I appreciate the help, but sad to say it did not work. I have changed the position of the ram, cleared the cmos by using the jumper and removing the battery, did a barebones check, took the board out of the case, had only the MB, power supply, and video, tried a known working IDE hard drive with Windows XP and still no luck. When it prompts me to press the DEL key to enter setup, it will attempt to enter the setup (with a rare quick split second sight of the setup screen), then the machine will shut down. I would think that you could access the BIOS setup without all the fancy gizmos attached. Allowing to get to the screen with the options of Safe Mode, Last known good configuation, start windows normally, I have tried all of the options, but all it does is sits there with the Windows XP screen and the bar moving. I removed the CPU, put new heatsink on it and secured it tight, still nothing. I have spent hours searching for a similar problem and have followed the given advice where I find it, but still nothing. I have swapped several keyboards and hard drive power cables, plugging it in every conceivable place I could find, but still the same results.
Was wondering if I should add the water cooling fan that says, ''for use in junction with Passive Cooler or Water Cooler ONLY'' to the top of the square ''snowflake'' on the MB (if that is where it goes), but on the fan package it says that installing the optional fan with an active CPU cooler will interfere with internal CPU cooler airflow and endanger system stability''. Looking through the MB box it came in, I notice a flat ribbon with ASUS stamped on it, about 3 inches long and about 1 inch wide with a rectangle box type connection at each end with slots for some sort of connection. Does this need to be installed??
Questions, questions. Such trouble just for what I thought would be a halfway decent computer that was given to me...now I know why it was replaced. At this point I am beginning to think I have a bad motherboard. I also gave thought to a bad power supply (400 watt), but not totally convinced on that, even considered a 600 watt replacement. So, with all this in mind should I just junk out the MB?
Thank you again in advance for your patience and help.
  • skidoonordic Jan 11, 2009
    Thank you very much for your solution! I did get a 700w ($169) PSU at Best Buy and it worked!! My hat's off to you and this site!
    President:
  • 948 Answers
After all you have tried, I would not bother with the water cooling. If the board does not work with air cooling, water cooling won't bring it around.
And in my opinion 400w is too small. I would not power the board with anything smaller than 750w, and don't use a cheap $29 power supply either. Power is the lifeblood of your system. Stick with good quality name brand power supplies.
Posted on Jan 06, 2009
CANNOT INSTALL WINDOWS XP AS IT SHUT DOWNS WHILE LOADING SETUP FILES AND SHOWS A BLUE SCREEN.
Hi deepakbandi2,
This could be as a result of a bad RAM chip or bad hard disk , due to bad sectors in it,
Please follow the below steps :-
  1. Make sure that you connect your RAM properly in the slot , if required remove the ram , clean it and change the slot where the RAM is fixed , for instance , if you had RAM fitted in slot one , change it to slot 2 , sometimes this could work fine.
  2. Try to do a full format of the partition that you select so that the files are copied properly, if this does not work try to install the operating systems on a different partition than you usually use, for e.g. if you were used to install the OS in drive c , try installing it on drive D , and make sure you have C and D drive formatted properly.
  3. If the above methods don't work , then try changing the RAM with one of your friends and check if everything works fine after RAM change , if it does , your probably need to buy a new RAM.
Hope this helps...:)
May 11, 2011 | Computers & Internet
Compaq evo will not boot up
try to go to BIOS
if the pc is not allowing you to go BIOS then get a bootable cd & insert the same & boot the pc to the desktop & also open the chasis & reseat the memory sticks.
Apr 10, 2009 | Compaq Evo D310v PC Desktop
Dell dimension 4700 computer keeps shutting down at start up
That's pointing to the memory. Try re-seating the RAM.
Mar 19, 2009 | Dell Dimension 4700 PC Desktop
Problem with pc
You probably need to check the cooling fan setup ( some motherboards give the control on the task manager or a sperate software to control it) This seems to be a problem of overheating which might have started after the installation of new ram.
Feb 28, 2009 | Intel Computers & Internet
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Dec 26, 2008 | HP Compaq d530 PC Desktop
Pc starts up and shuts down repeatedly and no video
First be sure that the ram (ecc)you have purchased is compatible with your motherboard and that it will take a total of 4 gig,make sure you earth yourself out on the case before going inside the pc (static electricity can damage electronic components)check that you have not accidentally loosened any data or power cables, check cpu & fan is seated correctly and working : then
  • put back the old ram and try booting up,(if still no good),
  • put things back to the way it was before the changes,
  • make sure everything is working as before (refer to the above)
  • trying the new ram, if ok
  • change cpu
  • this will identify if it is the ram the cpu, or some other problem
it is a good idea when upgrading the pc to do one thing at a time so that it is easier to identify any problems that crop up.
let me know how you get on
good luck
Terry
Mar 23, 2008 | Computers & Internet
Help me fix my pc please
It sounds like a cable is unplugged on the motherboard. Check all connections and be sure everything is pushed down firmly.
Please let me know if this helps. Take care, and good luck!
-Chimpster
Mar 20, 2008 | Compaq Presario 5000 PC Desktop
Computer wont start
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
check the power on pannel pins if they are in a good position too
Nov 14, 2007 | Computers & Internet
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
