Question about Kenmore 24 in. 17012 Built-in Dishwasher
Green ('Clean') light flashing
And the manual says to call the repair service and have them check the 'heater circuit'. Of course this machine has two, for heating the water, and for drying. Any ideas where to look for the problem? The annoying thing is that we never use the heating element to dry dishes, to save energy. But it may be that the sensor does not allow the machine to work if it malfunctions?
  • 883 Answers
Try this: fill the machine with cold water from your garden hose and start it up. the machine should recognize the water full condition and continue to start washing. wait about 7 minutes and stop it. open the door. did the water heat?
Posted on May 25, 2007
Flasjing green lights on an indest dishawasher which is not working
Hi, the flashing green light indicates a fault in the heating circuit of the appliance.
You would require to have, and be able to use, a multimeter to fully test the components. Check the circuit of the heating element (26 ohms).
Check for an open circuit heater cut-out.
Check pressure switch open circuit (connections 11-14).
Check wiring and connections between module card, pressure switch and heater.
If all above is OK, replace module card.
The heater and the module card are the most common causes of the fault. The heater is on the underside of the appliance and is attached to the top spray arm feed tube. The module card is in the facia of the appliance.
Jun 26, 2011 | Indesit Dishwashers
I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Model # 665.17032402 Clean light is flashing. Manual says to check heater circuit. How is the heater circuit checked? How is the heater element assembly replaced?
You need to check the thermostats in the heater circuit as well. The element is held in place my 2 nust from the bottom where the wires attach.
eric
Jun 29, 2009 | Dishwashers
My clean light is flashing....call service to check heater?
f the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water. Check the element for damage (burnt/shorted).
To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 05, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
Nov 27, 2006 | Kenmore 24 in. 16023 Built-in Dishwasher
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Kenmore 24 in. 17012 Built-in Dishwasher Logo
158 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
