Question about ECM Giotto Espresso Machine
Pump failure after warmup
The machine heats up, and will make one or two cups of espresso, but after a prolonged time, the pump will not turn on. If allowed to cool between cups, the pump will continue to work somewhat longer. It appears to overheat (although the barostat works) and the pump will not turn on. Steam is not a problem.
  • jwaldis Feb 08, 2009
    Sounds exactly like my machine. Please let me know if you find a solution.
    John Aldis
    jwaldis@msn.com
  • igroucho Apr 21, 2009
    My ECM Giotto pumps about 3 secs after lifting the lever all the way up (horizontally), stops for a few secs, starts pumping again, stops again and this sequence repeats for many cycles. Eventually it will pump a whole double espresso (or til I stop the brewing with the lever). Wazzup here??
    Problem Solver:
  • 9 Answers
Ther is a very simle heating cirquit with a prssure swithch including a Cherry micro swithc. This thing is rated max 60C. With time the plastic just get bent out of shape and you have no pressure. have fixed by changing the Pressostate or just the Cherry switch. The Element must come on at low pressure. It has an mechanical setpoint. So hotter coffe (higher steam press) can be set with a scew driver. Finally the safety valve lifts and you have learnt a little re boilers. Leaking safety valve need a new seal, Be careful,,if not, your ECM will serve the first espresso on the moon/// Olev
Posted on Mar 21, 2009
When I turn my keurig on(power button) the cold water immediately goes through the system into the cup. we have cleaned the unit but no change. Before this it was working perfectly
It could be the heating element inside the machine. Or I could be the water pump. The water pump pushes the water into a chamber where it is heated up before it goes into the cup. If there is a manual near by, read the part under water pump.
Apr 25, 2015 | Keurig Elite B40 Coffee Maker
I have a rancillio. The steamer works really well for about 15 seconds and then peters out???
Descale the boiler with citric acid.
  1. Turn off the machine and let it get cool
  2. Dissolve about a tablespoon of citric acid in the water reservoir.
  3. Turn on the machine and then pump about a cup of solution out of the boiler vent using the hot water switch.
  4. Turn off the switch. Close the vent
  5. Let the boiler heat up for about 5 minutes.
  6. Shut off the machine. Let the acid work for about 30 minutes.
  7. Check the level in the reservoir.
  8. Turn on the machine and then pump about a cup of solution out of the grouphead using the brew switch.
  9. Turn off the brew switch.
  10. Repeat steps 5,6, 7, 8, and 9 until the water runs clear.
  11. Wash out the reservoir.
  12. Turn the machine on. Pump a full reservoir water out the grouphead using the brew switch.
  13. Refill the reservoir.
  14. Have some coffee
Dec 02, 2012 | Rancilio Silvia Espresso Machine
Keurig B70 automatically pumps water when turned on
When you purged the lines or tubes retained debris and need full purging and flushing.
May 30, 2012 | Keurig Platinum B70 Coffee Maker
Will I still get coffee if the pump is broken. The machine is leaking staem and water underneath and I beleive it is the staem valve but a 'dodgy' coffee machine repairman is telling me it is the...
I am an expert espresso certified man. First of all your repair man is wrong. Let me explain. If you are getting steam at all, then your pump is not broken. This is the way it works, you have water in your machine, it goes into a area where it heats the water by heating elements, then as it heats it builds pressure by air and heat. The machine has a water pump in it, that operates by of course electricity, it pumps the water that is heated by the elements through the machine to of course make shots of espresso. The steam part is simular as it goes in a area, the gets hot and produces steam from the water, like a iron would of press kind of method. THE MACHINE will not make coffee or steam if pump is not working. If you turn machine on, and hear it humming or running, when trying to make a cup, then motor is running, if you turn it on and try to make a cup of coffee or steam and hear nothing at all, then pump is not working. If your machine is leaking under machine from from the steam valve, means it would not do that if pump is not working. Sense it is leaking, this tells me it is clogged. Most likely your need your machine cleaned good, that means descaled. Clean hoses, use small needle to poke in end of steam wand to clean out good jet air holes and basket screen. Find your manual, and it should tell you how to properly clean your machine, and even can use can of compressed air, that you can spray in hoses. It appears to be it is clogged, and when the pump or lines are clogged , it will back up like a clogged toilet and flood area around base and underneath. This whole problem is a cleaning problem, do to a clog or build up. I hope this. PS no if you pump is out or clogged, you would not get coffee as it need to the pump to work (unclogged) to push the water through the heads. Thanks Mike
Sep 15, 2011 | Gaggia Titanium Espresso Machine
My Mr. Coffee JWX27 won't brew. lights go on and the machine clicks as if it is going to start but nothing comes out. I tried the cleaning mode with vinegar and water solution and still nothing.
The heating element has gone bad. It's time to replace your coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
Mar 10, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
Coffee maker did not heat
An electric coffee maker has an electric flow-through brewing water heater with a heating resistor controlled by a temperature dependent regulating switch responsive to the temperature of the heating resistor, and a warming plate heated by the heating resistor for maintaining the prepared coffee at a desired drinking temperature. Apparatus for adjustably prolonging the interruption of heating current 2 to 5 times the normal cooling time of the regulating switch is connected in circuit with the heating resistor and the regulating switch, and a manually actuated small quantity control means connects the heating current interruption prolonging apparatus in circuit with the heating resistor and the regulating switch. The prolonging apparatus may be an adjustable auxiliary electric heater in parallel with the regulating switch and thermally coupled thereto or an adjustable timer in series with the heating resistor and regulation switch and triggered by the opening of the regulating switch
Jan 31, 2010 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
I have a krups xp2070 that i just put a new motor in. When making espresso, the water pump does not turn off. Is it related to the little relay switch that connects to one side of the pump?
The unit is programmed to operate the pump for a very specific period of time depending on the function. Power to the pump is provided by the main power module but controlled by the control module. Either the module is not sending the right signal or the relay on the power module is stuck on. You could try programming the espresso time to reset the pumping time. Will the pump stop if you press the espresso 1/2 cup button again?
Dec 12, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
I have the krups espresso and caffe machine and i have no idea how to MAKE espresso (it's NOT the one below)...
turn on your krups espreeso to warmup the water, put one spoon of coffee in the handle, lock the handle and turn on the pressure button, and the coffee leaks in your cup, that's all
Apr 27, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
ECM Giotto Espresso Machine Logo
292 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
