Question about iLO V27DMBX Television
Ilo tv went black and white
I'm not sure the exact size but I just got a use Ilo kc01-f1 ( i think thats the model ) tv and it was working fine untill I pressed some sort of reset button in the settings now the tv is in black and white... any help?
We had bought the extended warranty, so we took it back and got a new TV of a different brand. We had to pay the difference, but it was worth it. The warranty even carried over to the new TV.
Posted on Apr 20, 2007
  • 14 Answers
SOURCE: ilo power cord
You may want to contact Funai. They are the company that makes the Ilo brand. Their parts department may be able to find the cable you need and order it for you. 800-242-7158
Posted on May 12, 2007
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
  • 8617 Answers
SOURCE: Ilo 26 inch tv
I am sorry, Thats the one manufacturer that I diont have any experience with. although I would quess that its a signal processor that may be at fault being that you cant switch inputs.I would try to resubmitt your request to one of the other experts that may be famillar with that manufacturer.
Posted on Jun 08, 2008
SOURCE: ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Posted on Oct 28, 2008
SOURCE: need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
Posted on Dec 08, 2008
0 characters
1 Points
42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
Jun 02, 2009 | iLO LCT32HA36 Television
Who is the manufacturer of the ILO 26HD Television?
the manufactured should be on the back of the tv- i have an ilo 27 flat lcd hdtv the name on the back is
Mar 15, 2009 | iLO 2600 Television
push the "Pic Size" button and make sure it is not on Panoramic, that setting stretches and warps the right and left side of the picture
Oct 22, 2008 | iLO 3200 32 in. LCD Television
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Need new remote
Hey you should try finding an exact replacement for this ilo hdtv. If you have your model number for your ILO hdtv you can go to a website like and look through their catalog for a new replacement remote control, which is the exact same remote you got in the box with your ILO TV and should work right out of the box, unlike most universal remote controls. If they can't help, there are alot of other major replacement remote companies out there! Hope I helped!
Jul 30, 2007 | iLO V27DMBX Television
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
Picture on 42 in plasma went black
No recharging....just recycling. ILO S-U-C-K-S !
Dec 28, 2006 | iLO 2600 Television
iLO V27DMBX Television Logo
269 people viewed this question
Top iLO Flat Panel Televisions Experts
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Flat Panel Television Expert? Answer questions, earn points and help others
