The "offline" indication means your computer is having a communication error. There are a few things you can do to troubleshoot this. First, turn your PC and your printer off. Then check the USB cable running from your printer to your PC to make sure it is plugged in all the way on both ends. Power your PC and printer back on. If this doesn't work, try plugging the USB cable into a different USB port. If this doesn't work, uninstall the driver, then reinstall it. If it still does not work, don't rate me yet. Shoot me some more details because I have more TIPS up my sleeve.
a client ask for p2 display in the machine, it´s a sharp am 900. Somebady help me what does...
(More)
a client ask for p2 display in the machine, it´s a sharp am 900. Somebady help me what does it mean.
I replaced splitter and wall jack because fax,copier sharing phone line with credit card machine.fax...
(More)
I replaced splitter and wall jack because fax,copier sharing phone line with credit card machine.fax is o.k.but credit card machine says''line busy''if I switch cords at the splitter port the credit card machine will work but then the fax does not.HOW can this be?they share the same line on a new splitter and wall jack.. thank you for your help
Screen reads Paper Jammed even tho there is no paper jammed in the machine. This is an older product...
(More)
Screen reads Paper Jammed even tho there is no paper jammed in the machine. This is an older product SharpUX-5l0A
