Question about Polaroid FLM-3732 Television
Poor picture, lines running down the screen (looks color bleeding). Is this an expensive problem typically seen with LCD TV's.
You have to reurn them back to company because they are unrepairable.
Posted on Mar 10, 2009
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Colored vertical lines bleeding down
sounds like a Tcon board issue or possibly a bad LCD panel. Can you post a picture of the lines? If so please respond to this same post for further assistance
Jan 01, 2013 | Samsung LN55A950 55 in. LCD TV
My Sony Bravia get a wide (about a foot) line up and down my screen. It goes off an on when it wants to. It picks up background colors and it stays like that for a while. What can I do?
I don't know what does your mean by "line up and down my screen", if the line goes up from the bottom to reach the top of screen then goes back down to the bottom cycles, that symptom I have never seen. But if the line goes off and on, very high probability is the panel defective (see the picture, the ICs inside the panel loose, shall cause the Vertical or horizontal dead pixel lines). It is the most serious issue on the flat panel TV. Because the manufactory sells the panels, price even excess the TV.
If you need more accurate diagnose, you can post a picture.
May 07, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
The picture bleeds down to a black screen. At
Ur main backlight video board is the cause,must replaced.
Oct 25, 2009 | Sanyo DP26746 26 in. LCD Television
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
Colored vertical lines on half the screen
yeah get a new tv, and not a mitsubishi, they all seem to have the same prob over time. the lines mean that your picture is on its way out
Apr 25, 2009 | Mitsubishi LT-40134 40 in. HD-Ready LCD...
LCD TV Screen repair
I have a Sharp LC52XD1E TV , It has a crack on the screen needs a new screen can it be fixed and is it worth the repair?
Feb 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Color bleeding - blue colors always on the screen
just came across this same prob on my projector. Any ideas?
Dec 11, 2007 | Canon LV X2 Multimedia Projector
Televison & Video Logo
138 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
