Question about Vtech Cordless 6041 Phone
My Phone will not connect to the base unit...
Vtech DECT 6.0 Dual Handset Cordless 6041 Phone, the base will ring but the phone is stuck on "Connecting" I tryed unplugging it and plugging it back in, and that didn't work. do you know what will fix this problem?
  • 1 more comment
  • Anonymous Jan 21, 2009
    Only had phone about 1 week. Will not ring when my number is called, goes straight to voicemail after one ring. Also, says "connecting....." on both handsets. Tried taking battery loose and reconnecting to no avail. Probably will return to BestBuy.
  • bdajos Mar 17, 2009
    I have the same problem with these phones...they are searching for a dial tone and will not work. Frustrating to no end!
  • orionschart May 02, 2009
    my phone does charge but it still says connecting
    Scholar:
  • 47 Answers
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Posted on Jan 06, 2009
  • beccals76 Mar 14, 2011
    I had a similar problem. I tried taking the phone battery out, disconnecting the power to the base, and disconnecting and reconnecting the phone, waiting about 30 seconds before I reconnected for each of these. Not sure what worked, but about 5 seconds after I completed all of these, the phone was back online. This is the second time this has happened, but the phone seems to function well except for this.
My vtech digital 6.0 cordless phone says not registered but when someone calles the base of the phone still rings and people are able to leave messages but the actual phone isnt ringing, how can i fix it?
The base and the handset are not communicating. To have them do so, you need to "register" the handset with the base. Since you neglected to specify the model of your VTech DECT 6.0 phone I can't tell you how to do that. I can suggest you enter the model number into the search box here to download a copy of the manual. The manual will give you instructions on how to register the handset.
Jun 22, 2012 | Vtech DECT 6.0 Digital Cordless Phone
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
Bought a spare 3111 handset and cant connect it to my base. it looks as if it was connected to another base at one time. screen just says "connecting..." and there is nothing I can do to clear...
The handset must be registered to the base unit if the system has multiple handset ability, the manual will tell how to register the handset. If the system is a two handset system then only two handsets can be registered.
Dec 08, 2010 | Vtech Cordless 6041 Phone
Phone screen just say connecting
If is says connecting then most probably its not getting a connection from the base. It could also be your telephone line. Check if the line is active.
Please rate if helpful.
Thanks
Apr 19, 2010 | Vtech Cordless 6041 Phone
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
One 6041 handset will not connect, while the second handset does.
Unplug the entire phone set system from both electrical power and wall jack for approx 2-3 minutes and replug.
It's a reset measure that allows the entire system to reset / reboot as well as stops any and all line feed memory from the live phone line to hold the fault.
Such can be somewhat common when sharing the line with a DSL connection or wireless router is in use.
Jul 27, 2009 | Vtech Cordless 6041 Phone
What battery do I need for this phone; VTech DECT 6.0 cordless
Open your phone and
check it, but I think this
is the right battery.
Batt-6010Vtech 89-1326-00-00
Replacement Battery For The Following Vtech DECT 6.0 Phone Models 6031
6032
6041
6042 6053
DS6111
DS6121
DS6121-3 IS6110
DS6121-4
DS6121-5
Jul 14, 2009 | Vtech Cordless 6041 Phone
One phone just stopped working
some DECT handsets have an internal fuse and please swap the batteries to check if both batteries are Ok
Nov 27, 2008 | Vtech Cordless 6041 Phone
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
Vtech Cordless 6041 Phone Logo
2,089 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
