You need to clean thermocoupling off it what the pilot lit uses to stay lit. you canuse sand paper or brush May need to replace, clean gas tubes on pilot also could be that
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
under each (the) oven behind a panel, is a red button it may be a different color from time. this has to be pushed and held while the pilot light under the oven floor is lit with a match. it has to be held to allow enough heat to activate the thermocouple, which will keep the pilot on. if this does not work there may be an additional problem
You need to check a couple of things, first is the flame sensor, second is the thermostat. Without anymore detailed info this is the most I can give you.
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
