Question about HP DeskJet 890c InkJet Printer
Printer Problem Printer is not responding and power is on. My documents have stopped printing for some reason. I don't know if it is a driver problem or what. I know it is something simple. Windows XP and a HP DeskJet 890C. Thanks
HI!. Most printers have a self test facility to do a test page without being connected to any PC. If you can find that out from the HP site, that's a first step. Also, check printers in Windows Control Panel to make sure it is the "Default" printer. Try to send a test page. e.g. right click on the icon for the printer, select 'properties' & look for "Print test page". If all these work then next you would open Windows notepad and just type in a couple of rows of text, then print. If that works, then you try your original application program to prove that it is the cause (somehow). Check all physical connections & re-load the s/w driver.
Also, you could take your printer to a friends place that has the same Windows OS and see if it installs OK. Try & test print etc.
Hope this helps you to narrow down the problem.
Posted on Jan 06, 2009
All print jobs stay in queue with epson all in one xp600 series
Hi Violet,
There might be a number of reasons due to which your documents get stuck in a printer queue. Overloading and driver issues are the major reason behind this. If you are simultaneously printing hundred of documents then sometimes your printer jobs gets stuck in the printer queue. Then if your Printer drivers are corrupted then also while printing the documents sometimes it might get stuck in the print queue.If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Scan problems
Hi there
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X5650 All-in-One InkJet Printer
I do not seem to be able to print any documents even after uninstalling old drivers and installing new ones what is wrong
Apr 24, 2010 | Lexmark X1270 All-In-One InkJet Printer
My hp office jet 7210 takes several minutes to
I suspect that you are looking at a flow control issue and not a printer failure.
You can check the printer driver and make sure your printer options for background printing.
Also, make sure that your document is not too busy. I've had customers complain about slow printing documents and when I examined the documents, I discovered that there were multiple images overlay ed. The data still had to be sent, but only the top image printed.
Don
Nov 05, 2009 | HP Officejet 7210 All-In-One InkJet...
My printer is not responding to my computer.
Go back into Printers and Faxes, delete your printer icon, restart your PC and reinstall your printer driver. Good luck.
Jul 01, 2009 | HP Hewlett Packard Officejet 7310 InkJet...
Printer is not printing at all
You may not install the correct driver for the correct OS. Not sure what OS you are using but below link might be useful for you to get the correct driver and install into your PC.
http://etech.maiila.com/hp-deskjet-3845-driver-manual-software-download-and-troubleshooting-tips
Hope this helps
Nov 13, 2008 | HP Deskjet 3845 InkJet Printer
My canon mp210 is not responding to printing requests. we have replaced both colour cartridges. note: printer will photocopy a page, but again, it will not respond to request to print a word document, for...
Is there any blinking of light when the print command given. Any error message at printer display or Computer Screen ?
There is some problem in printing options. Please check and make default setting in the Printer properties. Go to Control Panel --> Select the printer --> Open printer window --> properties --> make them defauls --
During print command check whether the spooling in printer window goes completely or not (if it stop in middle )
Let me know in brief to solve this problem before going to reinstall printer drivers and do not vote till you recieve a good solution for this problem.
Nov 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer Problems
have you tried to right click on the printer icon in your task bar at the bottom of your screen? once you do that, you can highlight the document that is showing, right click and cancel printing.. you can also cancel all jobs.. let me know if this helps, if not, do you have the original cd so you can uninstall and reinstall the drivers? if not, i'll need to know what type of printer to find you the link to the driver download--this will just reset the printer and it should work fine.. good luck, d
Mar 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing-Supercalc 5-Spreadsheet-, Sideways
just to check if the printer and the printer driver is working properly, try printing a 2 page document.
if it prints out correctly - check the applications documentation / user guide for printing instructions.
Dec 28, 2007 | Office Equipment & Supplies
HP DeskJet 890c InkJet Printer Logo
152 people viewed this question
Ben Johnson
