Question about Kitchen Ranges
Oven light underbench oven light not working.have purchased new light bulb however cant seem to remove the casing, that will allow me access the old bulb. have no idea why ?instructions for the oven says to simply twist anti-clock wise but casing feels fixed ???
I had the same problem and worked on it for HOURS! Spray a tiny bit of WD40 on the glass fixture near the back of the oven. Wait a couple minutes and it will finally "give" and turn counter-clock wise. This part was clearly OVERLY tightened by the manufacturer.
Posted on Mar 25, 2009
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
The thermostat light will only come on momentarily on the highest setting oven and grill will not get hot ?
Your thermostat is faulty and needs replaced. SWITCH ALL POWER OFF. You should be able to do this by first removing the inner panel in the oven, this will give you access to the stat bulb and allow you to unclip it. Then remove the oven and remove the top panel and back panel of the oven. Then remove the knob for the stat and unscrew it from the front panel. Then screw the new stat into place and swap the wires over onto the corresponding terminal like for like. Then feed the bulb down the back and into the hole the old 1 came out of and replace all the panels that where removed. This should solve your problem. Hope this helps.
Apr 15, 2011 | Ovens
I am trying to purchase a new light for a Panasonic micr Oven B756 ENGLAND OR SPAIN PLEASE HELP
It is a standard bulb, and should be available at any electrical outlet. Remove the old one as a sample just in case. The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Apr 11, 2011 | Panasonic Microwave Ovens
The bulb lighting the oven no longer works, but we cannot see it anywhere. How can the old bulb be accessed and replaced?
When you remove the outer case, the lamp is situated tucked up behind the door switch mechanism on most microwave ovens and as I have no idea what model yours is, I have to guess.
Hope that helps.
Jan 08, 2011 | Panasonic Microwave Ovens
Cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Light bulb going out
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Cant get oven to work
hi Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
Nov 06, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Replacing dashboard lights on an 2000 Oldsmobile Silhouette Van?
the light bulbs are not replacable unless you can solder, you have to replace the complete instrument cluster, get one from a junk yard 100 bucks.
Jul 24, 2008 | 2000 Oldsmobile Silhouette
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
