Question about HP PSC 1350v All-In-One InkJet Printer
HP 1350V all-in-one
My printer has been working fine until it ran out of ink. I refilled the cartridge and tried to print but it keeps telling me print cartridge error. I tried to clean it and it keeps telling me the same thing.
  • burmezegirl Nov 06, 2007
    I am getting the same error, telling me to check print cartridge.
    Problem Solver:
  • 9 Answers
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today
Posted on Oct 29, 2007
  • WiseWoman Oct 29, 2007
    date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
    Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
  • 385 Answers
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
Posted on May 25, 2007
HP5550. Color ink ran out. Replaced with refilled cartridge, ink light still flashing. If I use an original cartridge this does not happen. Shop tells me cartidges are fine and proved it
some HP printers do this after a non original cartridge used The printer should still be able to operate even with the light flashing. If this does not work you may require to replace the print head.
Mar 21, 2011 | HP DeskJet 5550 InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
. HP 6210 all in one Kept printing till unplug
HP will tell you to never refill cartridges because they will not guarantee your printer will print properly with those refilled cartridges. If those refilled cartridges leak and cause damage to your printer HP will also not cover any repairs to the printer regardless of what sort of warranty coverage you have with them. Warranties only cover HP failures, not ones caused by using third-party or refilled ink cartridges. So, no it is not worth having the cartridges refilled - buy new HP-branded ones only.
Jul 25, 2009 | HP Office Equipment & Supplies
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Hp photosmart all in one C5280 -recommend keep cartridges topped up before they get past half way
for a succes refilling you can find averything you need in this kit
http://inkfilling.net/start-pack-a-hp.html
 each time you refill a cartridge you mast remove all air bubbles and old ink from cartridges
in this pack you can find refill clip to remove it
Oct 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Yellow Light on HP K550 indicating open panel will not turn off.
If the printer is connected to your computer - check to see if there is a blinking Red exclamation point / printer icon in the system tray. Sometimes mousing over this icon to see the tooltip is the only way to figure out what error message the printer is trying to tell you.
For us - when this happens, the printer is complaining about an "incompatible" ink cartridge - even though 99% of the time it will print from that cartridge without problems. So try removing and re-inserting all of your ink cartridges too.
Sep 30, 2008 | HP OfficeJet Pro k550 Printer
It keeps telling me to remove and check cartridge
I also have this same problem. I currently have refilled cartridges in there purchased from cartridge world. I never had any problems with my HP until i tried refilled cartridges for the first time about 6 months ago. When i first purchased a refilled cart. it took 3 trips back to the store until i got one that would work in my HP. so im wondering if this is why i am now getting this "remove and check cartridge" error message.? I am reluctant to go out and buy a new HP ink cartridge just to find out ill have the same problem....
Jun 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Ink cartridge stalled
hmmm..did you clean and recalibrate your print heads after replacement?
also, you might want a fresh set of print drivers. get em here
Mar 10, 2008 | HP PSC 1350v All-In-One InkJet Printer
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Ink replaced, but sows nothing
A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1350v All-In-One InkJet Printer Logo
291 people viewed this question
Clive
Clive
