Question about RCA Televison & Video
I was watching TV went to another room came back it was off will
Not come back on if I push the power button on TV it dosent do any thing but if use the remote the power light on the TV will flash on and off quickly
  • terryboley Jan 07, 2009
    Unplugging the system from the power supply didn't solve my problem. Is there any other power supply tricks I could try or if it's the power pack how do I install it????
  • 916 Answers
When the set shuts down or won't turn on it is because the protection circuit has captured the power management circuit and is keeping it from powering up. The protection circuit is like an intelligent fuse. It keeps the set off to avoid damage from power overload. Some section of the tv is drawing too much current or power from the power supply.
The most common problem associated with this is the breakdown of the high voltage section. IT is driven by the horizontal deflection amplifier. If the picture comes on some of the time it means the high voltage may be unstable and sometimes will work and sometimes not. You must determine what is going on. Unless you are a trained tv tech, you will have to call in an expert who can do a diagnosis and tell you what needs to be replaced or repaired.
Posted on Jan 07, 2009
  • 505 Answers
This could be any number of internal failures. I always start by trying the hard reset option..
-Unplug AC power from the wall. Wait about 1 minute
-Plug back in, wait a couple seconds, and try turning it back on.
Sometimes this will help if the computer crashes or glitches.
With a VCR combo, the whole thing won't come on when a tape gets jammed. If this happens, you can open the back and turn a small wheel to eject the tape, and sometimes this will fix the issue. If you do this, DON'T touch the big red wire with suction cup on the end - suctions to the tube (crt). This can have 30,000 volts and needs discharging or avoiding. Let me know what help I can give if you procede further.
Posted on Jan 06, 2009
Had power outage kill power, while tv was on evering thing went off everything came back on except tv
Check its main power regulator board. There is a protection fuse on it. Check it.
Nov 29, 2012 | Toshiba 30HFX85 TV
The minute finger dosent reset to 0 how do i resolve this issue. Model number OT1030
pull the crown to its last position then push the upper button to adjust until 0 then push back the crown to finish. i hope i have been helped you.
Jul 13, 2011 | Officina Del Tempo - Power - 49 - 52 watch
I was watching a DVD and I paused it to turn to TV and I turned it off on TV mode, when I went back to my room the tv was making a low screetching sound so I went to turn it on and it won't, I changed the...
Tries tv unplug,replug it back like an hour later.See,if that solved ur problems.If still have the same problems.The power supply board have the problems the causes,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Sylvania LD195EMX 19 in. TV
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Phillips 32 in. tv
bad front panel need to get new one ok sumthing loose or went out
Feb 04, 2008 | Televison & Video
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
