Question about HP LaserJet 3030 All-In-One Printer
Printing Suddenly, printing very faint. Have installed new cartridge. No improvement.
    Scholar:
  • 155 Answers
Check to make sure that a genuine HP print cartridge is being used.
Check to make sure that a toner low or toner out light is not being displayed on the control panel.
Try to reinstall the ink cartridge.
Check to make sure that EconoMode is off in the software.
Posted on Jan 06, 2009
    President:
  • 2,110 Answers
The media might not meet Hewlett-Packard media specifications (for example, the media
is too moist or too rough). See Device media specifications for more information. If the
whole page is light, the print density adjustment is too light or EconoMode might be turned
on. Adjust the print density and turn off EconoMode in the device properties. See Saving
toner for more information
use original hp cartg...
  • HP Master
  • 13,433 Answers
Check the print quality setting on your computer when printing from printing preferences try quality. Also optionally you may want to consider reinstalling the driver,s and uninstalling the printer completely first, as this will restore it to defaul settings.
  • 43 Answers
Is it faded all the way across the page, or is it for example more faded on the left that the right? With older printers you will sometimes get dust build up on the mirrors and lenses that can cause this problem There was a model slightly older than the 3030 that was notorious for this, but i don't recall which one. you can usually clean the mirrors and lenses with isopropyle alcohol. On the other hand It may just need a new image drum if its worn. How long since its been changed?
  • HP Master
  • 6,487 Answers
Try to do a deep cleaning on your printer using the printer management utility that is installed on your computer...
PRINTER SUDDENLY PRINTING VERY FAINT ALL INK FULL
It is most likely a blockage in the print-head. Run a nozzle check to see if all the jets are firing cleanly. If there are colours missing or "scratchy" run a deep cleaning cycle. If that doesn't improve the nozzle check, remove the cartridges and then the print-head. Run the underside of the print-head under hot water from the tap for a moment. dry it with a paper towel and re-install the print-head and cartridges. Give a standard clean and re-try. If it still doesn't work, the print-head is probably dying.
Mar 11, 2015 | Canon Office Equipment & Supplies
Www kodak com go support
We threw our 6150 into the trash (Florida does not recycle electronics) because it would not print correctly, even after we installed a new printhead and all new cartridges.
I recommend you cut your losses.
Aug 02, 2014 | Kodak ESP Office 6150 All-in-One Printer
I have a lexmark X4650 and the quality of the printing suddenly went very poor. Smudged and not clear at all. The printer is not used heavily and I have tried alligning the cartridges and cleaning to no...
Try to check the ink levels and make sure it's good for printing. Otherwise, please replace them with new cartridges. You can try to re-seat the cartridges in the printer then try to print your document again to verify that the print quality has improved.
Aug 14, 2011 | Lexmark X4650 All-In-One InkJet Printer
Black cartridge (HP21) will not print or prints faint 2mm strips (like a pedestrian crossing) of a broad black test piece on my HP Deskjet 2180 Desk. Colour (HP22) is OK. Cleaned cartridge manually per HP...
This type of cartridge has the printing head in them - the possibility that all 3 ones are clogged is extremely low. If you get a bad printing with them it's because the heads are incorrectly commanded - either the pin array that transfer the command is damaged and they will have to be cleaned and fixed or the processor of the printer is dead, and the printer with it.
Jul 09, 2011 | Office Equipment & Supplies
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Color suddenly stopped printing. black is printing fine.
Often ink printers will get clogged. This is especially the case if it sits idle for a while between uses, but can happen even with actively used printers. Try running the Dell printer's Head Cleaning Utility.
  • This is usually found by going to:
    Start > Control Panel > Printers and Faxes
  • Rightclick on your printer's icon
  • Choose Properties off the new menu
  • Click Maintenance
  • From there you should see the controls for Printhead Cleaning.
You should see an improvement after about 2-3 cleaning runs. This does use ink, but may be your best bet to resolve the issue.
Hope this helps,
Chris
Mar 23, 2009 | Dell Inkjet 720 Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Oct 20, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Printing faint text and image?
Have u tried replacing the entire fuser assembly ?
Mar 06, 2007 | HP LaserJet 1320 Printer
HP LaserJet 3030 All-In-One Printer Logo
260 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
