Question about Kenmore 73952 Gas Dryer
Won't spin My dryer is no longer spinning. I am sure the belt is gone but when I remove the back panel, there is no belt. Where is it?
    Sergeant:
  • 311 Answers
The belt is thru the frount.asuming there is noise when you start the dryer and its not turning,yes belt.if wont start at all other things to check first starting with door switch.check with me if need more help.ps if wanting in thru frount.pop top and remove frount door pannels.God bless ,tom
Posted on Jan 06, 2009
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
May 18, 2014 | Dryers
Samsung dryer, model: DV317AEG turns on, but won't spin
Could be the motor is full of lint. Depending on how mechanically inclined you are take the belt off and spin the barrel and the motor separately motor should spin free, barrel a little harder to spin,but spin at least a quarter turn after letting go.
Jul 05, 2012 | Dryers
My Dryer (VHC391) wont spin and just makes a humming sound as if trying to start, But after removing the back panel, if i spin the fan at the back to start the drum spinning it spins no problem. Has one of...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Hoover VHC391 T-80 Dryer
Please check the belt connecting the motor and drum. It could be loose or worn out. Also clean the belt with water. Check the couplings and ensure that they are not loose or worn out.
Sep 03, 2011 | Dryers
The drying turns on, but does not spin
Welcome to FixYa.
Sounds like it has a broken belt based on your description of your Asko dryer "The drying turns on, but does not spin".
You can visually inspect it be either removing the lower access panel or the dryer top panel, the choice is yours and either way will let you check the belt.
To go infrom the top remove the screws at the back of the top, they will be three #25 torx head screws.
Once the screws are out, slide the top towards the back slightly and lift up. You should then see something like this...
Oct 01, 2010 | Asko T761 Electric Dryer
My tumble dryer only spins with a helping hand once it goes its fine but does not spin on its own until i spin it manually to get it going then shut door quick
sounds as though the belt or maybe one of the rollers is wearing out. You will need to unplug the machine, open the dryer door and remove the screws, take a flat tip screw driver and pry gently on the top corners(as there are clips,that are connected to the top of the dryer) gently move the front panel forward and disconnect the door switch, sit panel aside, lift up on top lid of dryer(it has clips on the back so it will not fall off) and look at the belt and pulleys, note the routing of the belt, the rollers/coasters are on the back wall of the dryer, you will need to take belt off and lift up and out on the drum, sit drum aside and look at the rollers they should be round and spin freely. Hope this helped tim
Sep 18, 2010 | Zanussi TD4100W Electric Dryer
My dryer rumbles when it is spinning. But it also does not spin at times either. There is heat and when the tumbler does spin, the clothes come out very dry, so heating is not a problem. I'm just...
Ok you have a simple solution to repair your dryer if handy with simple tools. First purchase a belt for the drum and a roller for the belt tensioner. Sears will sell this in a kit form at any Sears store. The top of the dryer will have to come off then the front panel. The front section of the top will be needed to pry upward to remove upon when you remove the rear brackets on the back of the dryers top section. After removing the top, unplug all electrical connections. all should be diffenerent in shapes and sizes which is helpful to you.
The front panel may have screws on the sides that have to be removed.
Some models has a small secondary lower panel that simply pushes down and pulls out for removal
Now that the dryers drum is exposed you need to pull the straight drum out.
Now you will see the tensioner with the roller attached. The roiller you have on your will probably has a frozen bearing and a flat spot on the roller that causes the thumping noise when spinning. The belt has been stretched by the roller being uneven so long making the drum to stop when using you dryer.
Install the tensioner and weave the belt in through the tensioner and wrap it around the drums backside with a helper helping you
With some help you can slip it back in and reassemble this dryer.
Apr 10, 2010 | Dryers
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
Dec 21, 2008 | Whirlpool LER4634J Electric Dryer
Dryer
your belt or idler arm has fail,you need to remove to lint filter screw then the top,pull the top froward then up,remove to front panel screws on top,remove front panel,look at the top of tub and see of you see the belt,if not your belt has failed,pull the tub out the front ,also check the ldler arm on the bottom right,make sure the wheel is spinning free,get the model number off dryer,most times it's inside the dryer door or on the top back panel,get the new part from the appliance store and follow the direction that come with it,hope this helps
Jun 02, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
