Question about Linksys Wireless-G WRT54G Router
Change my mtu speed to 1364 for xbox live - Linksys Wireless-G WRT54G Router
  • 928 Answers
On a computer connected to the router.
Open an internet explorer browser. Click on the address bar and type in 192.168.1.1 leave the username blank tehn the password is admin unless you changed it. After that in the first page you should see the option for MTU. change it to manual then after that type in 1392 instead of 1364 then save the settings.
Posted on Jan 06, 2009
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
Hi. I want to change the MTU to 1364 so I can play on Xbox live using my zyxel P660 DW .
Can you play with XBox Live *without* changing the MTU ?
If so, then the "default" value can be used.
Sep 28, 2010 | Zyxel P660HW-D1 Router
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Connection interruption while playing xbox live
Xbox LIVE recommends using an MTU value of 1364(defaults are 1492 and 1500) on your router.
You will need to log onto your Router, go to the setup section, locate the MTU, set it to Manual, and change the Size to 1364.
If that doesn't work, you will need to clarify the following:
  1. How many machines(do you have other computers?)
  2. What router are you using
  3. Ethernet or Wireless?
Sep 28, 2009 | NetGear WGR614 Wireless Router
Xbox live is saying that i need 1364 mtu setting were do i go to change this.
that 1392 is a firewire, your xbox is in need a connection going to your firewire... install the firewire 1364 driver...
Jun 16, 2009 | Arris SURFboard SBG900 Wireless Router...
Mtu failure
Things to try:
Sep 30, 2008 | Video Game Consoles & Games
Xbox live mtu
That setting should be on the Setup page. Your best bet is to add the TCP and UDP ports to the applications/gaming page. Check the XBOX faq's for those port numbers.
Jun 02, 2008 | Linksys Wireless-G Broadband Router
Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
114 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
