Question about Brother IntelliFax-2820 Laser Fax
Faxes coming out almost all black
I have three big black streaks on all my faxes
  • 215 Answers
Take drum unit out, look on top and move plastic blue tab from 1 side to the other a few times. very important to make sure you replace the tab to the side it was originally on or you'll get a big, broad black band.
hth,
razors
Posted on Jan 12, 2009
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Streaks of black ink down the pages of faxes
Hello.
It might be as simple as changing the ink. If still a problem, the FAX may need cleaning.
Hope this helps.
Apr 02, 2010 | Brother IntelliFAX 4100 Laser Fax
Papers come out with black streeks on them from my sharp FO 4450
If everything is coming out with streaks, it's most likely your cleaning blade which is part of the drum cartridge. I've also seen this from 3rd party toner. Get Sharp toner for your Sharp fax if you don't have it already. If your black streaks are only on copies and sent faxes, this indicates that your scanner is dirty. It's located where you feed your paper in. Lift this part up and you'll see a strip of glass running front to back about 1/2 inch wide. Clean it and that will get rid of lines.
Oct 12, 2009 | Sharp FO-4400 Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
May 11, 2009 | Sharp Office Equipment & Supplies
Getting big black streaks though copies
OK I am guessing this is a Laser Fax or an Inkjet Fax- If it's a Laser Fax,chances are you may have a "BAD" drum and if this is a Ink jet most likely and "Leaky" cartridge.
May 01, 2009 | Office Equipment & Supplies
Thick black streaks on pages coming through the fax
remove the toner cartridge and you should be able to see the matching black streaks on it, if it is the problem .....don't bother trying to clean it , it is supposed to be self cleaning and you can't improve this look...replace
Mar 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Black streaks on paper when printing message
That green bar is the drum unit. Black streaks are indication of bad drum. Replace drum unit. Don't wait too long or it will ruin the fusing section as well from excess toner build-up. Big bucks!
Please do not forget to rate your replys please.
Nov 21, 2007 | Sharp FO 3500 Plain Paper Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
