Question about Brother IntelliFax-2820 Laser Fax
Im having a problem with my faxes being almost all black when they come out.Please help me to fix my problem.
    Problem Solver:
  • 7 Answers
Try cheacking the black levels in your printing prefrences.
Posted on Jan 06, 2009
When I fax the recieptent is getting 2 big black lines..........ive tried cleaniung it but not sure if im cleaning the corredt parts..........there a little glass part that looks like there may be ink
Open the auto sheet feeder (where you place your originals), look underneath and you will see a narrow "scanner" glass that the originals are scanned across. Clean this thoroughly with glass cleaner (or water) - there is probably correction fluid or some other foreign dirt on it. If you make a copy for yourself (before and after) it gives a good indication of the quality you are sending to fax recipients.
good luck, and please rate solution
Apr 28, 2009 | Brother FAX-575 Plain Paper Thermal
Im getting the same problem.. When I send fax it comes out black
The optics probably need cleaning. Unless you know something about them, I would take it to somebody who does for cleaning.
Apr 08, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Black lines on incoming faxes
Pull out the drum cartridge. There should not be any toner on it.
(it could be defective [drum cleaning blade] especcially if it's a refilled unit.
There might be a small blue tab on top of the unit that you can slide back and forth to clean the charge wire.
But then again, if you just changed the drum, it sounds like it's defective.
Sep 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Failure of machine to fax blue ink text
basically the fax paper is printed by inducing heat on the paper and it could be only black...
no inks are used in fax...
so it ll always be black
Jun 02, 2008 | Office Equipment & Supplies
Sending and Copying Problem
THE SCANNER NEEDS CLEANING HAPPY FAXING OMNIPRESENT
Mar 27, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
