I'm trying to find out where the power button plugs into on the motherboard
  • richardbyers May 11, 2010
    what type of mother board is it
  • 948 Answers
There will be two rows of metal pins about five mm tall. They will be labeled with white letters. Something like HD, PW, RS, depending on what your motherboard connects to those pins. If you post the exact motherboard you have we can perhaps find you a photo or diagram.
Posted on Jan 06, 2009
When i plugged power cable to my pc cpu fan start without press power button
It should start for a few seconds, the fans should spin and then stop. You should be able to power it up as per normal. If that is no the case then you are having hardware issues which could be the Power supply
Apr 03, 2011 | Intel 845GE Motherboard
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
P4VXASD how to plug in the power button
Do you have a Manual for this motherboard? Have you tried downloading one from the motherboard manufacturer's website.
They are usually pretty straightforward in explaining how to connect the power, power LED, Hard drive LED, Speakers. All usually plug in to one area of the board SB
May 20, 2010 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Dell dimension 4600 will not power up.
Hi there if your computer is not receiving power you should try plugging it in a different wall outlet first, if the problem still exist try a different power cable. If the problem is not solve you should change the power supply,and if the computer still does not receive power the you would need to replace the motherboard.
May 19, 2010 | Dell Dimension 4600C PC Desktop
No display, no cpu fan running, no any beep but led on mother board is on.I replace power supply but no result
Do the following to check motherboard.
1. Take out all cards from motherboard except video card. Unplug ribbons to CD-Roms, hard drives and floppy drives.
2. The only thing plugged into your motherboard should be video, keyboard and ram.
3. Check once again that all the power connectors from the power supply are properly plugged in. There may be two or three of them depending on the type of motherboard. Try turning on system. If you get no response then try next option.
4. Find the wire coming from your power on button and trace it to the motherboard. Pull the wire off and use a screwdrive to short between the two posts. If the power button is bad this should start the computer. If not your motherboard is probably toast.
Sep 30, 2009 | Intel D845GVSR Motherboard
The computer does not start
Make sure at the very least that the power cable is plugged into the wall (or a UPS) AND into the computer (and it is switched on).
Try power button, if nothing happens then...
Look inside the computer, make sure that you have wires running from the front part of the case (usually near the power button) to some pins on the motherboard...
If not then you need to figure out what wires are what and plug them onto the pins (use the motherboard manual to figure this out, or the internet; google your motherboard name + jumper settings)
Try power button again, if nothing then try another power supply.
Post back if you have any further problems.
May 08, 2009 | Intel Motherboard
Solid orange light on motherboard when power light is plugged in
the light on the motherboard indicates power to the board, so it's completely normal. that might be the same for the power button light.
Nov 15, 2008 | Computers & Internet
No power
Make sure you got the power switch plugged in the right front panel connector
make sure the ATX_12V is plugged in as well as the ATX
Oct 07, 2008 | ASUS P4SGX-MX Motherboard
CUW-AM no power
Try you system with a known working power supply. Your power supply could have an intermittent problem. It could be a lose wire or a capacitor problem. Putting back your system, Plug the 20 pin/24 pin power connector to the motherboard, plug the 4 pin extra CPU power in place, plug the panel connectors(Power button, reset button, LED...).
Sep 15, 2008 | ASUS CUWE-RM (CUWERMSWA) Motherboard
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
