kawasaki Quad Bikes Logo
Anonymous Posted on Nov 10, 2012
Wiring diagram for a reset button on a razor e-100 scooter
Clif Roberts
Level 2:
Habit-Forming:
Scholar:
  • Expert 89 Answers
  • Posted on Feb 13, 2015
Clif Roberts
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
89
Questions
Helped
87641
Points
245
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
wiring diagram for a reset button on a razor e-100 - 2a0b7f10-2c7e-4ffc-b7d7-ab4ce6d1545e.jpg
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Google Link to what could be the Electrical Diagrams for E-100
1helpful
Where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
12helpful
3answers
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
E-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Top kawasaki Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a kawasaki Toy Expert? Answer questions, earn points and help others
