Question about Fuji FinePix E510 Digital Camera
Card Error When I Turn On My Camera And Try To View My Pictures That I Already Have Taken On the Screen It Says "Card Error". Even When I Put The Card in A removable slot In my Computer To Upload Them It Says Card Is Not Formatted.
  • steve perry Dec 28, 2007
    when i turn camera on it says card error. i tried to format card in camera and it says card not initialized. bought new card and does the same thing
    Genius:
  • 2,985 Answers
Then it is safe to assume there are no images on the card. But to be sure go to www.convar.com and download PC Inspector. Install the program. put card in the slot and run the programs- if there are images on the card this program will find them. Saveany to a folder then take thae card out and format it in the CAMERA and only ever format it in the camera.
Posted on May 25, 2007
SOURCE:
Hi, my Cyber-shot DSC-H55 is displaying System Error C:32:01 everytime I try to view pictures that have been taken. This happens only when I try to view pictures taken and I have to turn off the camera in...
for all those who c.32.01 error is an error related to contacts camera card reading virtually fail to read the card. for this problem must disassemble the camera and exert a little pressure on each contact then to reinsert the card and restart the camera
Jan 23, 2011 | Sony Cyber-shot DSCH55 Digital Camera
My g.e camera always indicates picture error when i try to view
taken photo might have not stored well,memory card/card reader problem so clean chaqwue and adjust.
Mar 16, 2010 | GE A730 Digital Camera
SD CARD DOES NOT SHOW PICTURES ALREADY ON IT IN FUJI Z35
Your previous camera wasn't another Z35, was it? Most cameras will not display pictures that were taken with another camera. The old pictures are most likely still on the card. You can plug the card into a card reader and transfer them to a computer.
Mar 14, 2010 | Fujitsu Cameras
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
Unidentified Image
Usually the only time this message will appear is when you have taken the picture with another camera and try to review it on another. If this is not the issue, try formatting your card. Try another card. It may be a faulty memory card. If none of this works, call Canon tech support for free support.
May 28, 2008 | Canon PowerShot S51S Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
My camera wont take pictures card read error
I took a pictures with my camera and now some I cannot view some of the pictures it says Picture error
Dec 20, 2007 | Olympus FE-100 Digital Camera
Memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Oct 22, 2007 | HP Photosmart M525 Digital Camera
Fuji FinePix E510 Digital Camera Logo
52 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
