Question about New Home HF-2022
Are there any other feet and plates for a HF 2022?
Would like to know if I can get a walking foot, a clear foot, and a single hole needle plate?
  • 65 Answers
Here is a link to order the walking foot:
Newhome Sewing Machine Presser Feet & Attachments
Posted on Jan 06, 2009
Singer Quantum XL-1 the needle strikes the left side of the presser foot/needle plate in the zig-zag mode. How do I correct it. I have a new needle.
have you got the correct plate installed for zigzag sewing
it is the needle that jumps side to side and if you are using a single hole plate that will cause the problem
Oct 30, 2017 | Singer Sewing Machines
Just replaced a cracked throat plate on Juki DDL8700. It runs great but noticed presser feet are not parallel to dogs. Looks like presser bar has shifted a degree or two counterclockwise. A problem?
1. Did you replace the needle plate with one that had the same item #? If not, It might night be fitting quite right.
2. Did you unscrew the feed dogs at the same time? When I replace my plate, if I have had my feed dogs unscrewed, I put the screws in loosely until I set my plate because they are adjustable to fit correctly with the plate. Once my plate screws are in and tight, I tighten my feed dog screws so it fits evenly in the plate.
3.As a general rule, your the bar that holds you foot, doesn't move when you break a needle. However if you put a new foot on, it may not fit quite in the same way.
Good Luck!
Sep 29, 2017 | Juki Sewing Machines
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
When I sew silk or fine fabric the thread breaks and the fabric bunches up, what am I doing wrong, I first had the A foot and changed to B, changed the needle and still the problem persists
Check to be sure you are using needles and thread that are compatible with the fabric. Generally, finer threads will work better on fine fabrics along with a smaller needle. Be sure to change needles frequently as dull, bent, or nicked needles will cause very frustrating issues.
All About Needles
Remove the thread completely from the machine. RAISE the presser foot and rethread from the beginning, making sure the thread path is correct.
Some machines have a presser foot pressure adjustment (consult the owner's manual). Adjusting the pressure that the presser foot applies to the fabric & feed dogs is helpful when sewing especially fine or heavy fabric. Also, when sewing fine fabrics, loosening the tension could be beneficial.
Changing presser feet may also help, ie try using a straight stitch foot vs a presser foot for zig-zag stitching.
Something else you can try is finding a presser foot with a teflon finish or a roller foot that will glide or roll with the fabric through the machine. Even if you can't find a brand name presser foot for your particular machine, an adapter shank can probably be found that would allow you to use snap-on feet of all different designs and uses. Provides a lot of choices for presser feet for less than purchasing a brand-name presser foot. There are snap-on kits available on eBay and other auction sites.
Some machines also can take a straight-stitch needle plate--usually an additional accessory that can be purchased. The hole where the needle penetrates the needle plate to access the bobbin thread is actually a small round hole. With a zig-zag needle plate, the hole the needle penetrates is a wide rectangular hole that can allow fine fabrics to be pulled down through the hole. Zig-zag capable machines usually have a zig-zag needle plate as standard.
Feb 22, 2016 | Sewing Machines
My needle on my Esante seems to be hitting something the skipping stitches. I have changed needles, rethreaded, changed plates, and changed feet. Thanks
Did you thread the machine with the presser foot up? Is the needle inserted with the flat side to the back of the machine?
If so, and the problem has not changed, check the bobbin case to be sure it is correctly placed into the race. Leave the needle plate off as you hand walk the needle down. If it hits the case, it is not in place.
All the above has been done and problem continues, take the machine in for service as the timing may need adjusting and is a process best done my an authorized Brother dealer.
Mar 11, 2010 | Baby Lock Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Apr 05, 2008 | Janome 8080 Computerized Sewing Machine
New Home HF-2022 Logo
160 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
