Question about George Foreman G5 Indoor Grill
I need to know the temperature for making waffles
I lost the manual for my grill I want to know what the temperature is for the grill when making waffles.
I finally found the manual for this grill. It says that waffles should be cooked from 3-5 minutes on high uingd 2/3 cup of batter. There is an entry on this website where you can download and print the manual with suggested cooking times.
Posted on Jan 07, 2009
0690005 part number
ereplacementparts.com‎
Presto Power Cord - Amazon.com
Indoor Grills in Brand:Presto ' eBay.
go to google and type in the type of grill it is with the part number and it will bring up these sites to look for a new chord.
Nov 05, 2014 | Presto 07030 1500 Watt Electric Grill w/...
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
Jan 11, 2013 | Kitchen Appliances - Others
Waffle iron not heating
see this steps and fix it. God bless you
f the appliance does not heat, make sure that power is on at the outlet and test the electrical corrd , replace it if needed. If this doesn't work, disassemble the unit and test the heating elements.
If the appliance does not heat to the proper temperature, check the thermostat contacts. Some cooking appliances have an adjustment to reset the temperature ranges; you'll need the owner's manual to do this job.
Oct 15, 2012 | Hamilton Beach 26500hb Waffle Maker...
Waring Belgium Waffle maker shorted out and blew house breaker.
The wire near the fuse is shorting out on the metal under the lower grill. Mine did that when I replaced the fuse and turned it on. If not under warranty, it is easier to replace it for $39.95 from Costco than the hassle of taking it apart and trying to replace the fuse, which involves the time to take it apart, buying a fuse and either the crimper and connectors or a soldering iron and high temp solder, since the regular solder melts shortly after it begins heating.
Nov 12, 2011 | Waring WMK300 Professional Belgian Waffle...
To whom it may concern, I lost my instructions
You can download the instructions manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
  • To magnify the text of the manual, click the [+] button in the Adobe Reader window.
Hope this solves your problem. Thanks for using FixYa.
Jun 22, 2010 | Black & Decker G48TD Grill & Waffle Maker...
My waffle iron WW150 is sticking and I need to oil it again - what do I do.
Suggest using a "high" temperature Baking & Grilling Spray. Avoid the general purpose sprays that will just gum up the grilling surface.
May 20, 2010 | Waring Pro Belgian Waffle Maker Waffle...
Lost manual and have no idea how temp. should be set
Thoroughly clean with warm soapy water, that is the surfaces where the waffle will sit then thoroughly dry plug it in have your mix remade when it starts heating up pour some batter on as a tester in the center of the lower grill close the lid and watch the steam when the steam starts to slow down your waffle is cooked depending on how done you like them you either take it out as the steam is slowing down or when there is very little steam, there is a lot of trial and error with a waffle maker and after using it a couple of times you will get the hang of it and know precisely or know closer to how long you like it to cook. Good luck and let me know how it works out.
goofballlovers
May 03, 2009 | Oster 3883 Waffle Maker
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
George Foreman G5 Indoor Grill Logo
1,335 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
