Question about Panasonic Lumix DMC-FZ20 Digital Camera
Zom button does not turn
I think there maybe something inside it feels stiff maybe some kind of pop or something Did not know if there is a way to remove to clean
  • 98 Answers
Your mechanical zoom assy is dirty inside pls clean the zoom contactplate
Rob
Posted on Mar 22, 2009
Hp mini 210 2090nr
If a key on a laptop keyboard stops working it's usually bad news for the keyboard as it may well need to be replaced. Test the 'feel' of the button. Does it feel different compared to other buttons when you press it? I.e. does it feel loose, stiff, wobbly or like it sticks? Stiff or sticky could mean there is something stuck under the button, loose or wobbly could mean it is mechanically broken. Sometimes turning your laptop on it's side and tapping it firmly, not hard, can release it if there is a mechanical fault. Unfortunately however I think the fault is most likely to be an unrepairable one. You could always plug in an external USB keyboard to check if it the G key responds just to rule out an operating system fault but it is unlikely to be that. If the G button works when using the external keyboard you can be sure it is your laptop keyboard that is broken.
Replacement keyboards cost around $30 (eBay). There's a good guide on youtube showing how to remove the keyboard. http://youtu.be/OOor4uZRM9g
Good Luck
May 01, 2014 | HP Computers & Internet
Zom macet, lcd bloor muncul reset button switch What's your problem?
Go to busytrade,be busy your trade.
Welcome busytrade,believe you come back with fruitful results!
welcome to visit www.busytrade.com to have a happy shopping journey!
May 09, 2012 | Panasonic NV-MD10000 Camcorder
1999 Tj Sahara Edition 4.0, 4wd light doesn't turn on when you engage it. How do I know if 4wd is working or it's just a burnt bulb? How do you change a burnt bulb?
This light is problematic as I had to encounter this as well. For what it is worth, the job of removing it to replace a bulb, most likely an LED will not be worth the time. You know you are in 4wd when your steering becomes a bit stiffer and when you make a sharper turn feel your axles kind of bind or get stiff. The steering feels tighter or "heavier" and maybe your power steering labors more in a sharp turn. Once you drive with it on and off and pay attention to these aspects, you will know you are locked in 4wd. You should also feel a slight clunk or release when you are driving and you take it out of 4wd.
Jan 01, 2011 | 1999 Jeep Wrangler
I have a white westinghouse model lt 350r 15 years old front loader. it just wont spin and i can't get it to drain. it looks like the tub inside has shifted, it sounded funny the last few times i used it....
To drain it, take a shop vac to the discharge hose to vacuum out the water. If the inner drum is sagging inside the outer drum or when you try to turn the inner drum and feel any kind of thumping noise, probally means that the spider support has failed. It can be expensive to repair.
Aug 27, 2010 | Tecnik TKL9260 Front Load Washer
Acura steering problem
Hey. What I would do first is to raise the front end up, and check to see if the wheels turn left and right manually; engine off.
Wheels turn free, prob the rack
Second, start it up and feel the P/S hoses. Feel for pressure flow when the wheels are being turned. if there is no obvious feeling of pressure change, then I would think that the rack was bypassing thru the spool valve. Replace the rack.
Actually, $890.00 ain't bad...make sure they do an alignment when they are done.
Hope this helps you out.
Jan 24, 2009 | 1998 Acura TL
Speedometer Stops
Most cars Speedometer cable connect to one of the front wheels, but you said your speedometer sometimes stop then your steering wheel will go stiff, I think you should fix or change your speedometer cable, maybe the cable broken inside. Fix it as soon as possible for your safety.
Speedometer cable has two parts, one is outside cable, mounted and connect to both speedometer and wheel.
The other one is an inside steel cable, outside cable protects the inside cable, because the inside cable turns as soon as you move the car. It is directly connect to the wheel gears and the speedometer inside.
If your car has speedometer cable, I think you need check it right away.
Your steering wheel sometimes stiff, you also need to check your power steering fluid level, sometimes cause this kind problem.
Hope this can help you and if you have more questions, please use whatever the Fixya allowed, contact me to discuss this matter and others. Thank you.
Jun 24, 2008 | 2001 Ford Focus
Play button broken
If you want to risk it. Try tapping on table maybe it will pop out. Try using a small screwdriver to make it go flat and then guide it up back into place and Try taking all the screws out and putting the button in thwen put it back together
Mar 29, 2008 | Nextar MA933A MP3 Player
T.V. TURNS OFF
Sounds like somethings over heating if you smell something. The wise thing to do if you know nothing at all about the tv repair is to call someone unless you feel convident enough to open it and look around very carefully and see if you can describe whats over heating or burning as if you keep turning on the set and it keeps smelling it will burn something out thats not burned out now.
Mar 24, 2006 | Mitsubishi VS-60609 60" Rear Projection...
Panasonic Lumix DMC-FZ20 Digital Camera Logo
79 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
