Question about Arris Touchstone 450a (CM450) Modem
My pc freezes
Removed both dvd's, tried separetly changed memory, reformatted, power supply and my pc still freezes
    President:
  • 1,865 Answers
Enter Bios Settings and select restore default bios settings. Install O/S and take it from there
Posted on Apr 15, 2009
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
Jul 09, 2014 | Acer X193W LCD Monitor
If I change boot set up in bios I cannot save it instead it freezes. I tried to reformat my hard disk after it got infected with trojans.
you have asus mb do this
remove hard disk ,cd/dvd rom and other devices as printer and floopy .
1- clear cmos methed for clear cmos (I) remove cmos cell. and plug it after 15 second. you will see menu for prees f1 key. (2) turn off computer , remove power cable (ac suplly) wait 15 second put a jumpher cap on cmos jumpher for 5 second.and remove.
after doing this plug the ac main power supply. turn on you computer go bios and save it as defalt by press f7.
Aug 18, 2011 | ASUS Computers & Internet
I have two computers with Mercury mother board but keep on restarting.
try this.
  • Remove your memory card and video card.
  • Clean the gold bars using a White eraser.
  • Now put them back and make sure they are seated properly in their slots.
  • If the problem still occurs.
  • Try disconnecting your cd/dvd drive in the motherboard then open the pc.
  • if it turns ok then turn off the pc and attach again your cd / dvd drive.
  • If the problem occurs again. it means that you are experiencing a low voltage.
  • I suggest you buy a new power supply for your motherboard with higher voltage.
  • Oh i forgot. if the problem occurs with the dvd drive disconnected, the problem maybe corrupted Operating System or Malfunctioned Harddrive.
  • Try installing Windows 7 without reformatting your harddrive to avoid losing your important data.
here is a tutorial on how to install windows 7 without reformatting your harddrive.
Goodluck. Hope my solution helped.
Jun 29, 2011 | Mercury Computers & Internet
Dvd burner not writing discs; - I have tried numerous programs to write data files to DVD. I have tried Nero, Sonic, Roxio, AstroBurn and I have also tried a new drive. I started with a Pioneer BD-Rom/DVD...
Hello Mike, hi. I can trace your problem to the freezing up of your PC, which may possibly be caused by a faulty memory module, try replacing the memory with new ones, (well you may need to buy) and swap the old ones. test again to see if the program freezes. = )
Nov 24, 2009 | Acer Computers & Internet
Hp dvd lightscribe dual layer burner problem
It could be that your drive is just getting wore out.
It could be the amount of data on your hard drive. I have noticed systems do tend to operate poorly once the hard drive get's 50% or more full. This is because windows uses part of the hard drive as memory so when the hard drive is getting full it has less memory to work with and things start to slow down and even freeze.
One slight possibility could be that the power supply has become weak and is not able to deliver the necessary power to the burner as it used to. One way to test this is to remove all devices that consume power from the power supply except for the necessary ones like the hard drive, keyboard, and mouse and see if it improves any.
If you have another computer or have a friend with a computer you can try the dvd burner in you can rule out the power supply or the rest of your system, for that matter, being a problem.
Sep 16, 2008 | Computers & Internet
Not start
Format the phone using *#7370#
Solution 2
Switch off your phone, remove memory card and after 2 min hold *, 3 and Call key to reformat to original.
Finally format your memory card separetely
Apr 10, 2008 | Nokia N72 Cellular Phone
My n72 hangs
Solution 2
Apr 08, 2008 | Nokia N72 Cellular Phone
My N72 Problem
Solution 1
Solution 2
Apr 06, 2008 | Nokia N72 Cellular Phone
Re N72
Solution 2
Apr 01, 2008 | Nokia N72 Cellular Phone
Camera freezing
try a new memory card. also try to reformat the memory card. dont take images you care about until resolved.
i would try to remove the battery for about 10 seconds, and then reinstall, then reformat the memory card. if you still have the same issues, replace the memory card. it that does not cure it, you have a warranty repair to manage.
good luck
mark
Dec 23, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Arris Touchstone 450a (CM450) Modem Logo
66 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
