Question about Philips 60PP9401 60" Rear Projection Television
Converge without the remote control
I have a philips tv 60pp9401 and i do not have the remote control. how to do you converge the colors without the remote control?
  • 15,935 Answers
This TV has auto convergence. There is no manual setting....
A technician would have to do any settings beyond the norm function of the tv.
The convergence controller may be bad.
Auto IntelliSense™ Focus—automatically adjusts picture
convergence at the push of a button. After reviewing a special
test pattern, optical sensors send position information to the
controller, which then corrects the pictures. Auto IntelliSense
Focus responds to the natural and man-made magnetic field
conditions where the projection TV is located, so you always
enjoy the best possible picture.
Posted on Jan 06, 2009
  • 1 more comment
  • blueextc3221
    blueextc3221 Jan 06, 2009
    http://www.remotes.com/store/philips/60p...
    link to purchase substitute remote.
  • blueextc3221
  • blueextc3221
    Here are the directions once you have the remote to enter maintenence mode..
    Adjustment Preparation
    1. The Cutoff Adjustment should be completed.
    2. Video Controls: Brightness to 90%; Contrast to maximum.
    Adjustment Procedure (Normal Mode)
    1. Input an NTSC signal.
    2. Press the Service Only switch on the Convergence board to enter the
    Digital Convergence Adjustment Mode (DCAM).
    3. Place the remote control transmitter into the Digital Convergence
    Adjustment (DCA) Mode by removing a battery, pressing and holding the 7 and
    9 keys, and replacing the battery.
    Display Remote Control Diagram
    Note: When the remote control transmitter is in DCAM, the TV button will not
    illuminate.
    Note: The remote control transmitter will time out of DCAM in approximately
    20 seconds.
    4. Press the Help key on the remote control transmitter. A green crosshatch
    will appear.
    5. Press the Exit key (this is the Phase Adjustment Mode).
    6. Adjust the data value using the keys specified in the chart below so that
    the data value corresponds to the chart value.
    Saving Data Values
    7. Press the Help key to exit Phase Mode.
    8. Press the PIP (-) key twice to store the information.
    9. When green dots are displayed, press the Mute key.
  • 61 Answers
  • 56 Answers
Some where in front or on the side there should be a little pannel box with all the little controlers. hope this could help you.
How to adjust the convergence setting in a phillips model 60pp9401 tv
Use your remote and goto the convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jun 14, 2011 | Philips 46PP9302 46" Rear Projection...
Hello, I purchased and installed one
You will need a original remote to make the changes to the multipoint and single crosshatches. Do a google search for remote controls to find the Philips remote.
Jun 04, 2011 | Philips 51PP9100D 51 in. Television
I own a 60PP9401 60 in. Rear projection tv. My red convergance was way out of line. I placed tv in the shop a while back,cost me $300 to get it fixed! Got set home, red still out of line,but not as bad. My...
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
Jan 10, 2011 | Philips 60PP9401 60" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have a phillips 60 in rear projection tv model #60PP9401. and it is exhibiting the appearance of double vision, can this be fixed economically
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
I have a 60pp9401 without a remote and am unable to function the intelisense to attempt to realign colors that are way out of alignment
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Dec 14, 2010 | Philips 60PP9401 60" Rear Projection...
Convergence
This set is made by Hitachi and uses two STK392-110, Sanyo amps to control convergence. You have likely one amps that is shorted causing the problem, but it's HIGHLY recommended that you replace both amps. Also it uses 1.8 ohm 1w resistors, out in front of the amps, for the yoke return circuit and one or more of them may need to be replaced if they are beyond tolerance.
For this job you need a soldering station, VU meter with a ohms test, desoldering braid and a skill level of 8 on a scale of 1 to 10. Anything 5 or above would be a category of someone schooled in electronics.
If you need to find a tech in your area I suggest http://www.tvrepairpros.com/
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
May 14, 2009 | Philips 60PP9401 60" Rear Projection...
Convergence problem on Philips 60PP9401
2.2 ohm 1 watt...................................T.
Nov 10, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
