Question about Xerox Office Equipment & Supplies
I get the fault code 093 317 displayes on the machine scr?en . I dont know what this fault meant. So if you know , please tell me what i should do to sholve this fault. My machine is XEROX DOCUCOLR 242
4 Suggested Answers
  • 8 Answers
SOURCE: Good Morning!, I have a
2nd Btr retract error Call Xerox service or go to Xerox.com
Posted on Dec 30, 2008
SOURCE: I have a xerox docucolour 242 with error code
RAP yellow dispense failure
Posted on Aug 09, 2009
SOURCE: xerox 242 fault code 042-326
foult code 093-317
Posted on Apr 27, 2010
Looking for fault codes F-7, E-5 and F-5, E1
We don't know what brand you have, so Google (brand) washer fault codes F-7, E-5 and F-5, E1 As you indicate you have a Maytag, that means this search: https://www.google.com/webhp?hl=en#hl=en&q=maytag+fault+codes+ Those specific codes are a lid switch and Shifter actuator fault
May 14, 2016 | Washing Machines
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Can someone please help me i need the codes for the starveiw boxes can anyone please help thank you
Hello
The codes to switch between computers are:
SCR LOCK + SCR LOCk + 1 or 2
(Hit the Scroll Lock 2 times to access the KVM, press the number of the port you want to access).
Auto scan all ports - SCR Lock + SCR Lock + S
The manual can be downloaded here...
http://www.startech.com/Data/ProductManuals/sv221dvi.pdf
May 01, 2010 | StarTech.com StarView SV221DVI 2-port KVM...
We have a HP 1050 fax machine. Usually when we send something, it displays send ECM and the number of pages. Occasionally it displays send G3 and the number of pages. I can't find anywhere in the user...
this is just the transition speed and line condition and you dont have to worry about it , the machine will give you an error code if the faxes dont go through alturnativly contact the reciever of the fax to check that they have recieved it
G3 means poor line condition
Apr 09, 2010 | HP 1050 Plain Paper Inkjet Fax
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
WD8074-FHB washing machine SE on display
LG washing machine error code SE indicates a “motor fault” although the code also says it could be a main PCB fault.
They recommend to... “try the motor first”.
It’s vague and you really need an engineer to try and sort this one.
You can’t possibly justify “trying the motor first” if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
I have a Maytag A/C window unit model number M6Y14F2B , 14000 BTU and on the display screen its showing a error code of EE. I would like to know what this means and can it be fixed.
Why should I tell you how I fixed the problem for free if you can't even tell me how to solve this problem for free. I just wanted to know what the error code meant and if it can be fixed or is the unit junk.
Jul 28, 2008 | Maytag Heating & Cooling
My washing machine bosch 2401 keeps displaying a fault code 03. I just replaced the drain pump? any ideas?
First unplug the machine; then check all your connections and harnesses. Possible while you worked some wires could have come loose. Re. the code look in your users' manual............or surf on this site going to Bosch washing machines, from 'washing machines' above.
Please tell me somethng after you get this - yes, no or whatever...... I have quite a few solutions for which there is nothing............dont speak gama, type!
Jun 03, 2008 | Bosch Washing Machines
Error codes
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Nov 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
73 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
