Question about Garden
How do i make it run again?
Just picked up an 8hp briggs and stratton vertical shaft engine that has been sitting for about 8 years with very little oil and no gas in it. I have already drained the oil, changed the spark plug, and replaced the fuel lines. What are the next steps I need to take to get it running again? Does anyone have a wiring diagram available? do i need to take it apart? Can I try new gas, carb cleaner and fresh oil or could I damage it this way? This engine does not have an oil filter and it is pull start. Please email your info thanks a million
mmarsh24@live.com
  • Christopher Lipscomb
    Christopher Lipscomb May 11, 2010
    need more info.. has been sitting for about 8....
  • 56 Answers
Check compression, clean out the carbureatur bole take of the stop wire from the coil, squirt som gas in the carb, try crancking it
Posted on Jan 06, 2009
Briggs and stratton 8hp wont run without choke
Have you cleaned fuel line and tank to make sure no restrictions to carburetor?
Aug 26, 2012 | Briggs & Stratton Ignition Kit 2-8 HP...
Sir's, I have 8HP Briggs & Stratton Synchro
The main cause for your problem is a carburetor, the needle valve is not fully closing on the seat. This allows fuel to keep entering and overflowing out of the float bowl. The fuel only overflows when the tractor is not running. While it is sitting the fuel travels down the intake, and most of the time the intake valve stops partialy open and the fuel enters the cylinder. The fuel sits on the piston and slowly migrates past the piston rings and enters the crankcase. After a period of time, the oil level rises and then gets pumped up and out the breather tube.
If you trailer this piece of equipment, you might consider useing a fuel shut off. The bouncing causes the float to open and close, thus causing the same effect.
Hope this helps, Matt
Dec 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 6.5 Ohv dies after running for about 10-15 minutes. I let it sit awhile then runs again. This is a vertical shaft lawnmower engine.
This is a classic symptom of a blocked fuel cap vent. Next time it dies, remove the cap, wait 30 seconds or so (for carb to re-fill), then try to re-start. If it works, replace the cao.
Aug 07, 2010 | Briggs & Stratton Garden
I have a B & S vanguard 20 H.P. vert. shaft, 8 years old on Simplicty tractor. Keeps fouling plugs. Clean or replace plugs and it runs fine for about 1/2 an hour then starts to miss, blacksmoke, and...
Anti-foul plug adapters might be a temporary solution (treats the symptom and not the cause).
Personally, I would take it to a good, reputable, small engine repair shop that has verifiable references, and have them repair it.
Aug 03, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need point gap setting for 8 hp Briggs and Stratton gas engine
If it is an older BS it will be .015 That was standard. In fact an old match box cover would work to set them if you could not find a guage
Oct 07, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
8hp briggs and stratton in a go cart. is feeling very underpowered compared to what i remember. hasnt done much for last 8 years. done basics but no better? any ideas
Make sure the governor baffle is working freely. and the carb has no crud in it. Chk out this site:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
Aug 04, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
160 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
