Question about Kenmore 24032\24036 Top Load Washer
Top load 80 series
Won't spin after the rinse, just makes a clicking noise
  • 2 more comments
  • jsasso16 Jan 06, 2009
    I believe so. It does drain
  • jsasso16 Jan 08, 2009
    okay, I thought it just didnt spin, but it's not agitating either. There was no water left in the washer after the cycle though.
  • risner50 Jan 09, 2009
    the spin won't work the little thing that get push from the lid is broke and I don't know how to get into the machine to fix it. please help thank becky
  • Jim Balcum
    Jim Balcum May 11, 2010
    Does it spin after the wash cycle? Check the lid switch. Does it drain the water out? Does it agitate correctly?
  • 135 Answers
You vary likely need the coupling between the motor ant the gearcase. Hope this helps!
Posted on Jan 28, 2009
  • 318 Answers
I would guess you have a broken drive coupling. it is very common and is not too hard to replace. you need to remove the control panel by hinging it backwards, then remove the 2 clips that hold the cabinet in place. the cabinet comes off as the front, sides, and top all in one piece. once that is off you will see the pump and motor. remove the clips holding them on and that will allow you to see the drive coupling. it will be cracked and thats the piece that needs replaced. about 20 bucks.
Posted on Jan 06, 2009
  • Tom Zwiebel
    Tom Zwiebel Jan 08, 2009
    same answer as before. you most certainly have a broken drive coupling. use the directions i gave before and that will get you up and running again.
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
My Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Apr 04, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Won't drain or spin
this is the moptor coupler
about 12 dollars and 20 mins f your time
Oct 03, 2009 | Washing Machines
My kenmore 80 top load series wont rinse top load wont rinse
drain pump is trying to drain. maybe have something in pump
Jun 22, 2009 | Washing Machines
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
