Question about Video Game Consoles & Games
X-box 360 1 yrs. old one red light on console, what is the problem, is it the harddrive or the adapter? Help
    Problem Solver:
  • 7 Answers
Usually the red light indicate that the hard drive has failed. you will have to mail it into X-box to get your unit serviced. it whould be under warranty and shouldnt cost you anything.
Posted on Jan 06, 2009
My x box 360 will not turn on & the ac adapter box light is lit up red
If you are getting a red light on the A/C adapter then your adapter has gone bad and you need to get a new one.
Dec 22, 2010 | Microsoft Xbox 360 Console
I have 3 red lights on it
try removing your harddrive and powering it on (without the harddrive).
You can also try replugging it in.
If neither of these work contact microsoft at 1-800-4MYXBOX and support should fix your 360 for free (you have a 3yr warranty against the 3 red lights), you will also receive a months gold supply for your inconvenience.
Feb 28, 2010 | Microsoft Xbox 360 Console
I play for +- 30 min and the powersupply goes on red is it the powersupply or the box
If you are getting a red light on the Xbox 360 power brick, That happens when the power supply gets to hot or its not getting enough juice. Try plugging it in somewhere else and see if that helps, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter
also check if the power connector is firmly connected or not behind your xbox 360, if you still have a problem, check if you can borrow another Xbox 360 from anyone you know and swap the adapter and console which would help you know where the problem is
If none of this works, call up Microsoft for further help and support, since your problem may require servicing of your console.
If you are getting a Red Ring of light on the Xbox 360 power button, please clarify since it requires separate diagnostics.
Hope you get back to gaming on your Xbox 360 ASAP
Dec 01, 2009 | Microsoft Xbox 360 Console
3 red lights box under 3 years old
RED LIGHT OF DEATH!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 motherboard or power supply.You can test power supply with a voltmeter from power supply wires to the connections on the motherboard. If no power or low power, the supply is bad. If there is plenty of power, then motherboard could have bad capacitor or chipset on it causing the problems. You can test those with an ohmmeter to see which component is not the same.
Nov 23, 2009 | Microsoft Xbox 360 Console
Red light blinking on front of xbox 360
How many red lights flashed? One, or three?
One means that your harddrive isn't seated correctly.
Three means that your console is more or less screwed, and needs to be repaired by Microsoft.
Apr 10, 2009 | Microsoft Xbox 360 Arcade
X-box360 one red light on console
1 red light tell you that your video cable is unplug or broken
2 red light tell you that your xbox are over heating
3 red light tell you that your heat sink is incorrectly installed because of the overheating
so for your problem make sure that your xbox is correctly plug and if it don't work again change your video cable for a new one
good lock :-)
Jan 06, 2009 | Microsoft Xbox Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
1 red light on 360
Make sure that all of the pins for the harddrive are lined up properly, and make sure that they aren't bent at all. If that doesn't work, it may just be a faulty drive, in which case you will probably have to replace it(the hard drive).
Mar 15, 2008 | Microsoft Xbox 360 Console
Xbox 360
if it is 3 red lights you need to call 1-800-4myxbox they will try to fix your problem if it doesnt they will ship you a box that you put your 360 in and ship it to them no charge. They will send a new one or repair your old and send it back. if it is just 2 red lights then your xbox has overheated and you need to let it rest. You should call the number i provieded and explain it to them they are microsoft's experts and will assist you as needed.
Dec 23, 2007 | Microsoft Xbox 360 Console
My xbox 360 not on ,its flash red light
http://llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 17, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
