Question about Kenwood KDC-MP2032 CD Player
Protect feature on kenwood car cd player
Was blasting music then the radio kicked off and said "protect". Nothing I'm doing can get it going again. Any suggestions??? Much appreciated. B
  • bruce raymond May 26, 2007
    yep, was reset button?? Back to normal and back to cranking tunes! Thank you sir!!
    PDoggie,
    Bruce
Yeah im in Belize Central America and that solution worked as well.
thanks
Louigi
Posted on Jan 24, 2008
I AM ARGENTINIAN THIS WAS THE SOLUTION. THANK CABEZA DE GATO
Posted on Nov 25, 2007
Yep man this is the rite solution.. it works
Posted on Aug 01, 2007
  • 883 Answers
There may be a small pinhole on the front panel. find it and insert a pin (with power applied) to reset your radio. if this does not work, then go to the kenwood website and search for your item and then search for an 800 phone number to call for tech support
Posted on May 25, 2007
I have a Technics SU-G91 amp that is stuck in overload even with no input. I have tried giving it a quick blast of air to dust and still nothing. All help is appreciated!!
Your Technics unit will remain in the overload (protect mode) state until component failures have been corrected. The output stages and/or associated components may have failed.
Sep 02, 2016 | Technics Audio Players & Recorders
Kdc-x796 kenwood radio sound goes low after blasting it whats wrong? i changed the speakers then if i turn off the radio its ok for awhile then starts going soft again
Sounds like an overload protection. Check to make sure your wiring is correct for what the amp load can handle. If you have it wired for a 4 ohm and your radio, I am sure, can only handle an 8 ohm then that is your problem.
Feb 04, 2016 | Kenwood Car Audio & Video
I have the xdvd710 when i start my truck up volumn is blastin every time!!!!! how do i get it to stop?????
The dual XDDVD710 RADIO has a volume memmory (it seems), it will go to the last volume setting that it was set to, not play to,(supposly to keep it from blasting you when you turn it on and you forgat u had the volume on blast).
To set it,
1 turn radio on,
2 turn the volume to desire Level you whant it to go when you turn it on (other Levels besside BLAST hopefully) ,
3 push the volume button in, that should do it.
Now you can play your music loud and should you forget that you had it on BLAST (to over come road noise) when you last played your radio, it should start at the preset volume.
Dec 09, 2010 | Dual XDVD8170 Car DVD Player
Write protection
I had this problem too but when I changed button on side off of hold it works just fine I felt so dumb!!!
Jul 06, 2008 | GPX MW3837 MP3 Player
Kenwood car stereo KDC-W3534 : warning message PROTECT
i had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Dec 19, 2007 | Kenwood KSC-310CCS Center Channel Speaker...
Amp protection
Hi, Off hand, I believe there is nothing wrong with the setup, maybe just not 100% compatible. It's just that the Sony Amp's protection is doing its job (just too good) and the stock radio is likewise doing it's job (but not too good). Just maybe, at poweron, the stock radio sends out a small burst output (maybe capacitor discharge) that we normally hear as a slight thump in the speakers which was when no Sony amp, ok. However, when you have added the amp, you also amplified the thump, which unfortunately the Sony protection reacts to. You can off course let it be since you have figured out a way to make it work or you can try and install a delay on for the power amp or separate it's power on from the stock stereo. The idea is to turn on the stereo with the Sony off and after a second or less, a manual switch or a delay activated switch will turn on the Sony. The idea is to switch on the Sony after the thump has finished. Good luck and hopes this gives you an idea. Pls post back how things turn up. Kind regards.
Aug 15, 2007 | Sony XM-2002GTR Car Audio Amplifier
Amp protection light
Hi again, Looks like you posted twice, in any case pls have a look at your other post @ http://www.fixya.com/support/t182326-amp_protection
Kenwood KDC-MP2032 CD Player Logo
321 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
