Question about RCA F36650 36" TV
I have an RCA TV, I am trying to connect my computer to it. My computer has an RCA cable in the back of the computer.
  • jason May 11, 2010
    what kind of video card do you have ?
    Sergeant:
  • 233 Answers
Is the rca orange or yellow? If it is yelow, you can plug an rca cable into it and run that into the video input on your tv... If it is an orange rca, that is a digital audio output. You can also get a SVGA (regular monitor plug) to DVI or Component RCA cable adapter at radioshack and other electronics/computer stores.
Posted on Jan 06, 2009
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Connecting wire between pc to tv
Depending on what type of TV you have, connecting your PC to your TV shouldn't be very expensive. Most newer models of TVs come with a VGA input.
Your computer has a cable to go to the computer screen, this cable is known a s a VGA cable, it looks like this:
Your TV might have a VGA input which looks like this:
All you have to do is unplug your VGA cable from your computer screen and plug it in to your TV so your cable will go fro your computer to your TV instead of your computer to your screen.
If your TV doesn't have a VGA input, it will have an RCA input which looks like this:
You can buy a VGA to RCA cable which will allow you to connect your computer to your TV which looks like this:
You can buy a VGA cable here:Click Here
You can buy a VGA to RCA cable here: Click Here
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | LG 22LH20 LCD TV
How can I connect my Toshiba Satellite A305-S6872 laptop to my TV?
Check your notebook for "S-Video / TV out" port that has a 7-pin jack instead of a standard 4-pin S-Video jack. Check your laptop before ordering this adapter.
The newer your computer is, the better chance that it comes with either a RCA Composite or SVIDEO connection. Some notebook computers also have video outputs on them. When buying a new computer always look for the words "TV out" or "video out" in the computer description.
If you only have a VGA connector and don't have an HDTV then your best choice is to buy a newer video card with an S-Video connector. There are other third party solutions out there but the quality is very poor and we do not recommend it.
The VGA port is the connector that's connected to your PC monitor (the TV like device that came with your computer). This connector is usually only usable for VGA Monitors or HDTV setups. If you have an HDTV this will give you the best image possible.
If you have an RCA Composite connector on the back of your computer, then you can use that. You may also need to power down your computer and reboot to be able to get the signal. You need an RCA Composite cable that will be long enough to reach from your computer to your PC. Connect the cable to the back of the computer to the back of your TV SET.
S-Video is superior to that of RCA Composite and will give you a clearer picture. If you have a fairly new TV you should have this connector in the back. You will need to buy an S-VIDEO cable, which you can buy just about anywhere you buy home video products. Connect the cable to your S-Video on the back of your computer and then connect it on the back of your TV
Jan 01, 2010 | Toshiba Satellite Laptop
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
I have a Magnovox video cassette & dvd player combo, model # DV200MW8. I have an RCA analog TV with 1 cable port in the back and 3 RCA jacks ports. Previously, my Maganavox VCR/DVD player was connected...
omg , haven't heard the word VCR in decade.
are you kidding? seems not.,
what's next 8track tapes? and Beatles? LOL ! "hard days night?"
omg 2, rabbit ears,, im blowing out a gasket laughing...
vhf/uhf analog tv is gone. now. (FCC rules ,dead) HDTV sure.
please say what you are up to the job.?
are you trying to burn VHS tape to DVD? nah.... that be me 16 years ago.... then gave all my VHS away at work. hated VHS, ugly mess.
i see, says the blind man!
you need a switch box.
yes, they still sell them like on ebay but not walfart.
Mar 13, 2017 | HP Compaq Presario V5204nr Notebook
How do i connect cable tv to my dell 2200mp projector
You can connect it directly with a composite cable. There would be a RCA(yellow) video output on the back of your cable TV. This is then connected to Video input(yellow) f you projector.
If your cable TV has Component output (threr RCA cable Green, Red, Blue), then these thre RCA could be connected to the similar one available on your Projector.
You could connect your sound als o thru the RCA out of Cable TV and input of Projector. But if you have a good AV Receiver or a sound system then it best suited for it, since the projector speaker is mono and only 2Watt output.
Let me know if there are any specific inputs required
The Dell 2200 mp projector has the following compatibility
:HDTV: 1080i, 720p
EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes
Mar 03, 2009 | Dell 2200MP Multimedia Projector
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
RCA F36650 36" TV Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
