Question about Kodak EasyShare One Digital Camera
My memory cards are saying they are locked and i need to format my cards when i do it it keeps sending me over and over again through the same **** ive tried all 4 card on lock and unlock and still nothign s working
    Genius:
  • 1,199 Answers
Try another brand of memory card alot of times all brands are not compatible withall devices even they are the same type of card
Good Luck! (if this does not work the camera may need repaired!
Please rate my responce!
Thank You!
Posted on Jan 06, 2009
  • 928 Answers
This means that you have to format the cards on a computer or on a card reader attached to the computer.
The camera keeps saying "Memory
It's not the camera. I hope you have the original card if not no matter. I'm including a diagram that shows a locking switch on an SD card the black arrow points to the little switch in the unlock position. Now something else you will need to format the memory card to make it compatible to your camera. This function is in "set up" and you need to use the arrow keys to navigate to that function. Format the card and everyone will be happy again. Another thing each time you download pictures to your computer you need to format the memory card. What I expect you are doing or have been doing is deleting the pictures. This works but eventually it leaves the card full of holes and dirty and the camera can no longer write to it. I full expect that if you still have the original SD car that you can format it as well and it will work again. Now saying that because it's so dirty (with old deleted information not actual dirt) you may need to format that card a few times (maybe twice). This will solve your problem
Diagram
Jan 07, 2011 | Kodak EasyShare C142 Digital Camera
How do u fix the camera that keeps saying locked card and its not the memory card
Not sure why you are saying it's not the memory card or is it because you are working on the camera internal memory? If so the camera internal memory still needs to be formatted or initialized to properly work with the camera. I'm going to include two diagrams on a memory card that your camera will use first is the Card Lock. This is an actual lock on the side of the memory card and if in the incorrect orientation will prevent formatting all new card must be formatted to the camera they are being used in. You can't format the card in the computer and expect it to work in the camera it won't happen. You can't format the card in one camera and place it in another even the same make and model and expect to work.
Here is the first picture/diagram of the card lock
The second diagram is right out of your owners manual showing how to format/initialize your memory card
Format card was taken from page 89 of your manual Have fun with your camera
Dec 30, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My memory card has been locked i dint keep any password i conneted to pc and clicked format but it says insert a disk plz solve my problem
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Nov 12, 2010 | Kingston 2GB Secure Digital Memory Card
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
My kodak easysharecamera keeps saying the memory card needs to be
I'm having the exact same problem! I have formatted 2 SD cards on the computer and it still didn't work. Every time I've tried formatting on the camera, it says it is and then says again that it needs to be formatted. I even went out and bought a whole new Kodak SD card, thinking I just needed a Kodak one, but no luck.
I can't help, but I was just wondering if you ever got the problem solved because I really would like to know.
Jun 01, 2010 | Kodak EASYSHARE M340 Digital Camera
I have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card requiers formatting,ipresse continue to start the formatting but it keeps giving the same message how do iformat...
The lever on your card might be turned the wrong way. Pls. readjust and try again.
The card might not be supported:
You camera Memory card support : SD/MMC up to 1 Gigabyte
Good luck pls. rate me and/or recommend me if helpful
TXS
Nov 28, 2009 | Kodak EasyShare C315 Digital Camera
Can not format memory card
I had that problem too back in the day and the camera wouldn't format the card. I believe it's an early sign of the camera on it's last legs of life.
Just plug the card into your computer and do it that way... Also double check that your memory card isn't set on the lock position that could be making the memory card a read only card at the moment
Aug 07, 2009 | Kodak EasyShare C330 Digital Camera
Sony w580i-mem card not showing files says not inserted
you have to check your memory card or you can put again in slot and try again
Jul 09, 2017 | Sony Ericsson w580i Cellular Phone
Chip wont format
there is a little white tab to the left hand side of the disk (as you look at te label side), slide it to the opposite direction of where it is, and try again.
The Write protection tab is in the lock position - it needs to be unlocked to transfer anything to it.
Feb 06, 2009 | SanDisk 2GB microSD Memory Card
Memory card needs formatting.
take a look at your memory card to make sure it is not locked, then try formatting you memory card
Dec 26, 2008 | Kodak EasyShare C713 Digital Camera
Kodak EasyShare One Digital Camera Logo
23 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
