Question about 3M Cable Assembly, Fiber Optic Duplex SC-ST Singlemode, (ICCICFOJ9C503)
How many fiber optic closures are needed in a 375 km fiber cable?
I have 375 km fiber cable how many closures do i need?
  • pauln37 May 11, 2010
    pls be more specfic
It depends on the drum length; if your drum length is 4km then you need 94 closure,
thanks
Nasr Kutkut
nasr@kutkut.com
Posted on Feb 15, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: how many fiber optic closures
Hi Jess,
Need more info. What is your application, is it a back bone, are there regular drop points etc. For long haul I would assume you are going to use Single Mode, G.655 fibre. depending on the active equipment You could get 80km between re-transmission points. from a practical point of view the cable drum lengths will also play a part. For a 72 core cable loose tube, Nylon Jacket cable a 8km drum is getting fairly large so I would assume that a splice joint would be need at least every 8km.
Hope this helps,
Cheers,
Jason
Posted on Apr 24, 2009
What is the difference between GPON B+ and C+ GPON transceiver?
B+ Module C+ Module Type One-fiber bi-directional optical module, class B+ One-fiber bi-directional optical module, class C+ Operating Wavelength Tx: 1490 nm
Rx: 1310 nm Tx: 1490 nm
Rx: 1310 nm Encapsulation Type SFP SFP Port Rate Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Tx: 2.49 Gbit/s
Rx: 1.24 Gbit/s Minimum Output Optical Power 1.50 dBm 3.00 dBm Maximum Output Optical Power 5.00 dBm 7.00 dBm Maximum Receiver Sensitivity -28.00 dBm -32.00 dBm Optical Connector Type SC/PC SC/PC Optical Fiber Type Single-mode Single-mode Reach 20.00 km 20.00 km Overload Optical Power -8.0 dBm -12.0 dBm Extinction Ratio Huawei GPBD Board Thunder link com
Nov 02, 2016 | Computers & Internet
Bose Lifestyle AV 28 Media Center and PS 28 need Cable Pin In/Out
Are u talking about the fiber optic cable in and out put of the system all u new is to buy a optic cable if u need a converter from optic to RCA here is the site to buy one on amazon Digital Coaxial Optical to Analog RCA Audio Converter Fiber Optic Cable New 6_26_2014_11_28_58_pm.png
Nov 12, 2013 | Audio Players & Recorders
Fiber optics termination
If it is loose tube cable, than you can do it in two ways. First using SC SM pigtails, which should be spliced on each fiber (don't forget that you need to protect the splice itself and protect bare fibers puttung them in same cassete or tray or ....) or the other way using "break out system" which will give your bare fibers more protection but the SC connectors can be mounted directly on the fiber in this system. Cheaper and preferable way is the first one.
If it is tight buffered cable there is also two ways of termination. First, directly mount SC connector on a fiber (no need for break out system) or splice SC SM pigtails. Cheaper and preferable way is the first one.
Sep 12, 2009 | Adapters.com Fiber Optics Cable SC/SC...
Hi Jess,
Hope this helps,
Cheers,
Jason
Jan 06, 2009 | Computers & Internet
Fiber cable running through a steam tunnel
use UTP cable to replace a fiber cable
Dec 05, 2008 | Seicor Fiber Optic Cable
Canary CFT-2062 connection diagram
I tried to answer this for you yesterday but FixYa didn't put it through I guess. I'll try again.
That device is a "Industrial Media Converter". It is for converting a 100BASE-TX LAN cable into a 100BASE-F fiber optic cable for long-range networking. (2km) There are two ways to use it.
One:
Get two and convert LAN to fiber, then back to LAN.
Two:
Use it to tap into an existing fiber network, like fiber optic Internet.
For the first case; you will need some "Duplex" "multi-mode" fiber optic cable ($1.10 a meter) and an other one of those devices ($50~$300).
For the second case you will also need some fiber optic cable and you will need a network to tap in to. Of course you will need to clear everything with the company that owns that network before you can do any thing. And that’s assuming that they even use the same system level protocols.
To directly answer your question:
1: Hook the 100BASE-TX LAN port up to a PC, Hub, or a switch.
2: Hook up TWO multi-mode fiber optic cables to the device using CT style connecters. Hook one to the TX and one to the RX connectors on the unit.
3: Run the cable how you see fit.
4: Hook the other end up to the interfacing device. Be it joining it to an other cable in an existing network, or to another of those devices.
Note: The TX cable of one device goes to the RX of the other and visa-versa.
-Charlie
P.S. I also have one exactly like that one that I’m trying to find a use for.
Nov 19, 2008 | Canary (CFT-2062) Transceiver
FIBER OPTIC
You don't need it, but you probably want it if you have an xbox adapter with a digital/optical connection. They are pretty inexpensive particularly if purchased online. Here is an example:
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=2885066
Sep 03, 2008 | Spherex Xbox 5.1 Surround Sound System...
Computers & Internet Logo
221 people viewed this question
Top 3M Computers & Internet Experts
Raj Patel
Tom Chichester
james laughton
james laughton
Are you a 3M Computer and Internet Expert? Answer questions, earn points and help others
